Reply 180 of 231, by DustyShinigami
- l33t
MagefromAntares wrote on 2026-06-17, 00:10:First I have to say the same thing that @Law212 said: […]
DustyShinigami wrote on 2026-06-16, 23:23:Really don't know what's going on with this system. It just won't accept the onboard graphics at all. Had to install the Geforce 4 card just to be able to use it. And despite installing the USB drivers so I can access other drivers, the response time/read/write speed is shockingly slow. To the point that the whole system stops responding. This was never an issue on my main setup. 🙁 It won't even copy/paste anything off the pen drive onto the HDD. Even something as small as 700Kb. It doesn't even run the onboard graphics drivers.
Law212 wrote on 2026-06-16, 01:23:Slow but steady. Thats how it goes sometimes
some systems are hard to get going at first but will become good performers once the issues are resolved, it will make it all the more satisfying when it finally "clicks" together 😀.
The onboard graphics not working is annoying, but if you have a dedicated graphics card then it will not matter in the long run anyway. For the USB data transfer you can try putting the drive into a different USB port, sometimes the problem is only with a single USB port and avoiding that makes things work better. If there is a constant data transfer speed issue when copying files and the system stops responding during these there might be a problem with the HDD, you can use a variety of programs to check for that, for example HDSentinel(https://www.hdsentinel.com/index.php) or if you are familiar with the Linux tool then smartmontools also have a version for Windows XP to download.
Ahh, bugger. I forgot. I did test the HDD out, using my IDE/SATA adapter on my main PC, the other day and for some reason it can't show much of anything about it. Same with my external HDD I've been using for years. It recognises it, but everything else is unknown.
The same happens with CrystalDiskInfo, too. I'll have to see if there's a legacy/Win9x version of both.
EDIT: Ahhhh, that's why. Just read it's because they're connected via USB, which can't provide enough power. Makes sense.
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
Sound Card: Sound Blaster Live Value CT4670
