Socket A: Aiming for the Stars!!!
Reply 340 of 543, by tehsiggi
_digitalbath wrote on 2026-06-17, 20:10:
A modified Arctic Copper Silent 3. I've improved the fan. :-P The reason why I am using it, the FAN blows directly to the VRM c […]
supercordo wrote on 2026-06-17, 19:54:
What cooler are you using?
A modified Arctic Copper Silent 3. I've improved the fan. 😜
The reason why I am using it, the FAN blows directly to the VRM cooler on my ASUS A7N8X board.
Did I say, I like Delta fans?
Used the same principle at the start. However the switch to watercooling via AIO was also bound to the wife-acceptance-factor. This way I can work on it in the living room, not only in my lab 😁
AGP Card Real Power Consumption
AGP Power monitor - diagnostic hardware tool
Graphics card repair collection
Reply 341 of 543, by Ozzuneoj
Man, this thread is giving me the itch...
I have had an NF7-S 2.0 with an overclocked 1700+ Tbred B for 23 years and I haven't really pushed it beyond 2Ghz in years just to keep it cool, quiet and consistent. I had it running at around 2.1 for a while and I think the highest I pushed it was 2.2Ghz. I'd hate to kill the poor thing after all these years of reliable service... but I am curious as to how it stacks up.
Also, I got a working Radeon HD 3850 AGP a few years back and it would be cool to get some crazy benchmark numbers with that.
Aaaand... I came into possession of a huge pile of Socket A chips last year and I was amazed that it contained several that are very popular overclockers, including some mobile Bartons I believe.
If I can get some other projects out of the way, I will eventually have something to post here too. 😀
Reply 342 of 543, by PcBytes
Yeah, the Barton score I have is end road for me. Will look onto hosting the 370 version of the Aiming For The Stars, seeing as there is none for that platform.
Reply 343 of 543, by zuldan
PcBytes wrote on 2026-06-18, 09:33:
You have a lot more room for improvement. You GPU is holding you back.
Reply 344 of 543, by tehsiggi
zuldan wrote on 2026-06-18, 09:37:
A GPU overclock will squeeze some more points out, that's for sure.
Reply 345 of 543, by PcBytes
The only CPU that I can get to up its FSB is superlocked, and the other ones I have don't clock enough to beat scores at all. The so-called unlocked Barton I was given with the board is absolutely refusing any FSB setting than 166 and 200, although I can confirm the multiplier does work downwards (surprisingly not upwards despite being a 0331 chip.)
On top of that the X850 score is the only time 3DMark cooperated - I could not get it to finish another run ever again, even after switching to 7800GS, instead it crashes around either mid-1st test or right after the 1st test finishes. The only case where 3dMark completes is the stock 3200+ setting offered from BIOS - anything past that and the crashes start.
tehsiggi wrote on 2026-06-18, 09:47:
Attempted already, it refused to run past the stock 520MHz core/540MHz mem settings, and would produce artefacts within ATITool when tested at speeds greater than 520/540.
Reply 346 of 543, by tehsiggi
PcBytes wrote on 2026-06-18, 09:47:
Bummer 🙁
I tried a 7600GS yesterday, which even refused to boot. Though the card itself works fine and the AGP clock is locked. Sometimes the combinations are just creating odd behaviors.
Reply 347 of 543, by PcBytes
tehsiggi wrote on 2026-06-18, 09:50:
Bummer 🙁
Yeah. On top of that- T-Breds I tested (2400+, 2200+ and a few Semprons) would POST with 7x multi instead of the desired multiplier, and outside of that they were horribly unstable. I'm not sure if that's my cooler not being up to par or the chips hating any VCore past 2v (I had them run at 2.1v). Couldn't get any Palomino to run although I feel they wouldn't have fared any better than my 1333 Thunderbird anyways.
Reply 348 of 543, by _digitalbath
tehsiggi wrote on 2026-06-18, 04:22:
I never had intentions for water cooling. I’m glad I can work in the basement; if I did it in the living room, I’d be permanently banned from the house in a heartbeat.
supercordo wrote on 2026-06-17, 20:16:
I have a THERMALTAKE POLO 735 EXTREME im thinking of throwing on to test.
https://www.legitreviews.com/thermaltake-polo … 735-extreme_135
To me, it looks similar to a TT Volcano 12. This 3 blade design is insane. I have it somewhere in a box.
Reply 349 of 543, by cyclone3d
PcBytes wrote on 2026-06-18, 10:02:
Bummer 🙁
That sounds like something else is at play. Having that many components that refuse to cooperate is very suspicious.
Have you tried a different power supply? If so, what brand and model and gold old are the ones you have tried?
Has that motherboard been recapped?
Do you have another socket 462 motherboard you can use to test?
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 350 of 543, by PcBytes
cyclone3d wrote on 2026-06-18, 13:40:
That sounds like something else is at play. Having that many components that refuse to cooperate is very suspicious. […]
Bummer 🙁
PSU: Chieftec GPS-350FB-101A (Delta, recapped), Corsair TX850M (v1, orange)
Motherboard uses Rubycons exclusively (no Nichicon)
Tested on 7N400 Pro2, same behavior across all T-Bred chips.
Reply 351 of 543, by geordiepingu
Re-enabled some more "go faster" bits and broke the 14k mark with 14242 at 1875MHz on the 2x Barton 2500s. Still awaiting some more supplies to start the serious tweaking.
Might not be as impressive as the NForce chipsets, which are a lot more modern in comparison, but still really happy with the numbers I'm starting to get out of this old 760MPX platform, especially with the added complexity of getting an old dual CPU rig remotely close in single-threaded benchmarks. Here's hoping I can break into 15k with the multiplier set properly. Build Thread
file.php?mode=view&id=244339
geordiepingu wrote on 2026-07-05, 17:19:
All for the benchmarks!
Petrol head and serial PC tweaker
Reply 352 of 543, by cyclone3d
PcBytes wrote on 2026-06-18, 13:49:
PSU: Chieftec GPS-350FB-101A (Delta, recapped), Corsair TX850M (v1, orange) […]
That is really strange. I've never had issues like that. Makes no sense.
The dropping to a lower multiplier on some CPUs is normal behaviour.
Have you tried lower voltage on the T-Breds? Default voltage is max 1.65v. I wouldn't feel safe going over 1.85v with excellent cooling unless using sub-ambient cooling and even then that would only be for max speed runs.
You should be able to get at least a couple hundred Mhz extra at about default voltage.
YMF7x4 Guide
Reply 353 of 543, by supercordo
The only CPU that I can get to up its FSB is superlocked, and the other ones I have don't clock enough to beat scores at all. Th […]
It wouldnt hurt to reinstall 3Dmark or windows for that matter. With overclocking things can get corrupt sometimes.
Reply 354 of 543, by supercordo
_digitalbath wrote on 2026-06-18, 12:56:
I never had intentions for water cooling. I’m glad I can work in the basement; if I did it in the living room, I’d be permanentl […]
Yeah, those delta fans are quite loud. Im single with no kids. I dont have these married life problems. If i see something on ebay that i want, i buy, and then i play with it. When i want!!!
Reply 355 of 543, by supercordo
Anyone remember or have one of these Tip-Magnetic Driving Fans? Up to 5600 RPM.
Reply 357 of 543, by PC Hoarder Patrol
supercordo wrote on 2026-06-18, 17:02:
Yeah, still have my Vantec AeroFlow
The attachment Vantec AeroFlow.jpg is no longer available
Reply 358 of 543, by supercordo
PC Hoarder Patrol wrote on 2026-06-18, 17:24:
Very nice!!!!
