First post, by AndAlphaAndOmega
No One Lives Forever 1 Game Of The Year Edition Revival Version & Contract Jack Revival Version Crashes to Desktop every time after running it on Windows 11 Pro 26H1 with following specification:
Device name MSIGL6612UGK
Processor 12th Gen Intel(R) Core(TM) i9-12900H (2.90 GHz)
Installed RAM 64.0 GB (63.7 GB usable)
Device ID 7607D1F2-6CED-400A-854A-A59B2B76970A
Product ID 00330-80000-00000-AA022
System type 64-bit operating system, x64-based processor
Pen and touch No pen or touch input is available for this display
Edition Windows 11 Pro Insider Preview
Version 26H1
Installed on ‎5/‎16/‎2026
Evaluation expires on ‎8/‎11/‎2026 8:09 PM
OS build 28020.2207
Experience Windows Feature Experience Pack 1000.26100.361.0
Please notice that I have tried all steps in these YouTube Videos available at http://nolfrevival.tk/ here: https://www.youtube.com/playlist?list=PL6x3DH … QrUnG_LoxOPqrtp
But Each time I try to run the games it CTDs and does not even start with no error messages, despite getting help from DGVoodoo it does not even start???
It could be something to do with dgvoodoo2 settings too??? I am not sure???
Please help me???
Any idea or suggestion will be welcome!
Thank you very much & Awaiting your replay!!!
Best regards,
Reply 1 of 17, by AndAlphaAndOmega
Hello,
This is a special message for Dege.
I have updated this message with some dgvoodoo2 v2.87.2 screenshots please view them and let me know what may need of change???
Thanks
AndAlphaAndOmega
Reply 2 of 17, by AndAlphaAndOmega
Dege or somebody please help me???
Thanks
AndAlphaAndOmega
Reply 3 of 17, by Dege
I only have NOLF and the original CD version of it. If I launch the game by NOLF.exe then it crashes for me too, after the initial title screen (fading in/out) before the video playback.
If I start lithtech.exe directly then it mostly works and survives the video playback section.
When it crashes then it crashes in binkw32.dll (the video decoder), it has a memory overrun bug.
I found a lithtech.bat file in my game folder, I probably created it for myself earlier, containing:
lithtech.exe -cmdfile nolfcmds.txt
File nolfcmds.txt is probably generated by the NOLF.exe launcher according to the game settings, it contains the following for me:
LITHTECH.EXE -windowtitle "No One Lives Forever" -rez NOLF.rez -rez NOLF2.rez -rez NOLFdll.rez -rez NOLFl.rez -rez custom +multiplayer 0  +DisableMusic 0 +DisableSound 0 +DisableTripBuf 0 +DisableHardwareCursor 0
Btw, you could use the debug version of dgVoodoo and attach the debug output log to see how far the game gets after it starts.
Reply 4 of 17, by AndAlphaAndOmega
@Dege
Thanks for taking time to answering me, but can you please tell me step-by-step what is it you wish me to do to troubleshoot this issue???
Thanks
Awaiting instructions from you now...
AndAlphaAndOmega
Reply 5 of 17, by AndAlphaAndOmega
@Dege so what do you say???
Reply 6 of 17, by NeoG_
Calm your farm buddy, people in the community are not your personal support team and they will respond if and when they are able to
98/DOS Rig: BabyAT AladdinV, K6-2+/550, V3 2000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, SB16-SCSI, PicoGUS, WP32 McCake, iNFRA CD, ZIP100
XP Rig: Lian Li PC-10 ATX, Gigabyte X38-DQ6, Core2Duo E6850, ATi HD5870, 2GB DDR2, 2TB HDD, X-Fi XtremeGamer
Reply 7 of 17, by AndAlphaAndOmega
Sorry!!!
Just thought it may be a good idea to remind after waiting for answer for 24 Hours.
But I see your point.
Sorry again!!!
Best regards,
AndAlphaAndOmega
Reply 8 of 17, by Dege
Try to run the game by launching lithtech.exe directly, with the command arguments as I described in my previous post. To do this, just create a .bat file and copy the one line I wrote into it.
Reply 9 of 17, by AndAlphaAndOmega
I have solved out the issue!!!
YIPPIYYEE!!!
Thanks everybody especially Dege
Reply 10 of 17, by AndAlphaAndOmega
Problem was that dgvoodoo2 v2.87.2 had a bug. Totally or at least DDRAW.dll file itself had a bug.
I have copied v2.86.5 files and it has start to work.
Can Dege please tell me why I can't make this game to work without using dgvoodoo2, because I can't???
Please enlighten me, Dege???
Thank you very much for your answers and support!!!
Reply 11 of 17, by AndAlphaAndOmega
Can Dege please tell me why I can't make No One Lives Forever 1 & Contract Jack to work without using dgvoodoo2???
Reply 12 of 17, by Dege
As I wrote, NOLF has 2 problems:
  • binkw32 (the video decoder) has a memory overrun bug. It either survive the memory overrun or not, depending on the memory allocation locations on a particular running.
  • If I launch the game through NOLF.EXE, the launcher, then lithtech.exe, which is the actual game executable does not get the window focus when it is started and the game exits in that case after the initial fading in/out screen. No such problem when I directly start lithtech.exe.
It's all for the same if I use 2.86.5 or the latest version, there is no difference between them regarding this game.
I did not yet checked out the other game, I don't have it.
Reply 13 of 17, by Gatekeeper
Don't know if this will help but... AvP 2 uses a Lith Tech engine pretty similar to NOLF's own. I stopped the game from crashing all the time by enabling the "override high DPI scaling behavior" compat option on the "lithtech.exe" file. That's the only thing that helped.
See attached screenshot.
Don't waste your time, or time will waste you...
Reply 14 of 17, by AndAlphaAndOmega
@Dege,
You may download NOLF1&2&ContractJack can be downloaded with torrent for free on REMOVED
Trust me or not the latest dgvoodoo2 version has bugs.
Thanks
@Gatekeeper, Thanks a lot
Reply 15 of 17, by Matchstick
AndAlphaAndOmega wrote on 2026-06-09, 21:18:
@Dege, You may download NOLF1&2&ContractJack can be downloaded with torrent for free on http://Nolfrevival.tk. Trust me or not t […]
@Dege,
Thanks
That is actually the same version and referenced by the OP
Reply 16 of 17, by AndAlphaAndOmega
I wrote that since Dege wrote he did not have that???
Reply 17 of 17, by Arramond
I have this working ok with NOLF 1 at least. Not tried 2 or CJ. I have installed the same Revival versions including The modernizer patch and the widescreen fix. Configured dgVoodoo as seen in the screenshots.
