First post, by wbahnassi
Hi guys, the Dell Optiplex 466LE I recently got has a drive cage in which 5.25" drives slide in and snap without the need for screwing them to the cage.. similar to many of the modern cases.
Bummer is the rails are proprietary and none of the common ones I have managed to properly fit... so, 3D printing it is.
I uploaded my design here:
https://cults3d.com/en/3d-model/gadget/dell-o … 6le-drive-rails
Hopefully it helps some who have a similar machine. I think many of the old Optiplex models used this system, so it's not just my specific one. My case looks like this:
The attachment Dell-Optiplex-466le-Intel-486DX2-66MHz-Desktop-Computer_163653__34991.jpg is no longer available
but I believe these cases use the same rails too:
The attachment Dell-Optiplex-466L-Intel-466L-Desktop-Computer_153880__59462.jpg is no longer available
Here is how the rails look like:
The attachment 20240704_084506.jpg is no longer available
The attachment 20240704_120606.jpg is no longer available
The attachment 20240704_120709.jpg is no longer available
Turbo XT 12MHz, EGA, MFM HDD
Intel 386 DX-33, Speedstar 24X, SB 1.5, 1x CD
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
IBM BlueLightning 100MHz, CL5428, SB16, 4x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, RTX2060
Reply 1 of 13, by Horun
Good work !
Reply 2 of 13, by Aui
This is incredible! Just right now I am fiddeling with some alumina rods and try to make a rail for a 5.25 drive for the very same computer (433L). Thanks for sharing. I dont have a 3D printer but I may just try to order these rails from a 3d printing service. Thanks for sharing.
Reply 3 of 13, by b_riera
This is very much appreciated. I will definitely give these a go and find somewhere online to print and try. I'll confirm if they work in the older style case but from the pictures, they look the same. I opted to just line up the second drive and carefully mark the screw holes, drill into the cage and use longer screws. It's a pain to align when I remove the drive. I really wish Dell just left spares installed in the empty bay but I guess those pennies add up.
Reply 4 of 13, by wbahnassi
b_riera wrote on 2024-07-06, 04:28:
Yes, the previous owner to my Dell did something similar. While he did not dig holes, he used extra long screws with washers to reach the drive and reduce its movement.. but it wasn't very effective.
Happy to hear those designs were useful to you guys. I already have them installed and they work great!
I, too, don't have a 3D printer. I got them printed at one nice dude's who offered 3D printing via Facebook. Cheap and local. I printed them with 100% infill to make them sturdy enough to handle heavy 5.25" drives plus user operation.
The design is made to be printed laying flat. Dont print them on the thin edge.
I also added supports under the raised edge of the rail to ensure it doesn't sag during printing. After you get the parts, carefully break off those supports. They are 1mm thin, and should be scored with something sharp first, then with a little force they will break off cleanly.
Enjoy!
Reply 5 of 13, by sirlemonhead
Nice one, thanks! I have the 466 case in your second picture and those rails look the same. I needed to mount a 3.5" floppy drive so used a Dell adapter like you have for your floppy drive. I think it was advertised as coming from a Dell Server case so this is probably beneficial for a few different models.
Reply 6 of 13, by wbahnassi
This is my case's original 3.5" drive and enclosure:
The attachment 20240708_122356.jpg is no longer available
As you can see, this one has the rails part of the whole plastic mold, so it's one big a** custom Dell part. But I don't think you need this for a 3.5" drive. You can grab a generic 3.5-to-5.25 bay adapter available on Amazon/eBay and add the 3D printed rails on it amd it will work just as fine.
In fact, I'm having trouble with this Dell 3.5" enclosure. I just don't know for the life of me how to take out the floppy drive. It needs cleaning badly and I can't seem to figure out how to remove it from the enclosure 🤪
Reply 7 of 13, by sirlemonhead
I recall you really just need to bend it away from the drive. It was a bit scary and maybe I wasn't doing it the right way but I couldn't see how else 😁
Reply 8 of 13, by b_riera
I finally got around to getting some of your brackets 3D printed. They work great. Thank you very much!
The attachment PXL_20251105_155527372.jpg is no longer available
The attachment PXL_20251105_155551365.jpg is no longer available
The attachment PXL_20251105_172059462.jpg is no longer available
Reply 9 of 13, by wbahnassi
Nice! Glad it works for your machine. What infill percentage did you use for printing?
Reply 10 of 13, by b_riera
Sorry, busy month at work. I chose 100% infill. Pricing wasn't different enough to worth risking any less. They feel fairly substantial anyway
Reply 11 of 13, by musehead
Just to say thanks for creating these models. I've printed them to fit a drive into my "old style" 466/L case and they work well. I used 30% infill for mine - I printed them before reading the rest of the thread. But all seems fine.
Reply 12 of 13, by wbahnassi
Happy to hear that. It is very satisfying to see them actually click and hold up the drives 😊
Reply 13 of 13, by DaveDDS
For those without a 3D printer - I've had "usable" results over the years with cutting and "adjusting" strips of plastic.
It obviously helps a lot if you have an existing set of rails you can copy, but with carefull measurements and some prototypine with thin cardboard strips you can usually figure it close-enough.
For the plastic "rails", I've used thick plastic jar tops (wide jars like penut butter ones work good - but if you can't find a bit long enough you can often get by with separate shorter front and back sections), or a couple thicknesses of strips of plastic siding.
If well made (helps if you have good tools like a table jig-saw and drill press) can support a drive quite well. Not always the prettiest, but fortunately drive rails tend to be well hidden inside the system.
https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChw can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small filetransfer(w/o netSW)via Lan/Lpt/Com
