First post, by Spikey
Hey there,
Curious if the DOSBox capture ability allows a toggleable setting to automatically capture MIDI data once the program is launched, without having to press default key combos or custom key binds. The use case is capturing MT-32 SysEx, which sends before a game is "live". I tried a few times using a custom single keyboard key, and each time a different amount of SysEx data was captured.
I'm using 0.74-2, if that makes a difference.
Cheers!
Reply 1 of 3, by NeoG_
I assume this is because the game is auto-launching? Can you not just launch into a command prompt, start the capture then start the game manually?
98/DOS Rig: BabyAT AladdinV, K6-2+/550, V3 2000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, SB16-SCSI, PicoGUS, WP32 McCake, iNFRA CD, ZIP100
XP Rig: Lian Li PC-10 ATX, Gigabyte X38-DQ6, Core2Duo E6850, ATi HD5870, 2GB DDR2, 2TB HDD, X-Fi XtremeGamer
Reply 2 of 3, by Spikey
Does that work? I honestly didn't even consider that lmao. I'll try it!
Reply 3 of 3, by Spikey
Yes, of course it worked.. Thanks Neo!
