First post, by Forevermore
- Member
Hi everyone,
I currently am setting up a GA-5AX Rev. 5.2 super7 board & I'm getting incorrect parameters. Right now, it's a K6-2 400AHX. Set it up as instructed in both the manual & on the board itself & I get 420MHz. As if it's running 105MHz FSB. CPU-Z also reports it at that speed for both FSB & Internal clock. I encounter absolutely no instability running it in this state.
Setting it at the jumpers for 105/70 posts the same result but with added instability also (crashes in BIOS). 66/66 does not post at all. BIOS version is F4.
I am at a loss to explain this.
So many combinations to make, so few cases to put them in.
