First post, by plasticfactory
Hello everyone, first post but I've been lurking for a while as I put together this spec list. The plan, like many others have shared here, is to build the "ultimate" catch all for DOS up to Windows 98. I haven't put together something like this since the 90's, so I am hoping for a bit of critique or guidance.
I look forward to any feedback, and if this isn't the right place for this, please let me know 😀
- MSI MS-6163 Pro v 2.0
- Voodoo 5 5500 (Win98)
- Voodoo 2 SLI (DOS)
- Aureal Vortex 2 SQ2500 (Win98)
- AWE64 Gold CT4390 (DOS
- Pentium III 1Ghz "Coppermine" SL4KL
- Crucial 256 CL2 / CT32M64S4D7E
- EVGA SuperNOVA G6
- Swissbit X60/X75 SSD + SATA150 TX2plus
- All the various bays and cables
I'm looking for any major pitfalls, "upgrades", or recommended sidesteps. I know the dual GPU/Sound card setup is probably not ideal, but is definitely what I want to do in the short term. Perhaps I can pull some of the parts for a dedicated DOS build down the road?
Reply 1 of 8, by RetroPCCupboard
Certainly that's a no expense spared kinda build. Will look forward to seeing it in action. What case are you using?
Reply 2 of 8, by Mike_
How about an Athlon XP build with Geforce 4 ti GPU, AWE64 in ISA slot and *maybe* a single Voodoo 2 if you want that for some DOS games? Yes, there are KT133/KT133A boards with an ISA slot. That should handle games further into 00s without losing much compatibility.
Reply 3 of 8, by Fish3r
plasticfactory wrote on Yesterday, 17:01:
A Tualatin P3 would really complete the 'spared no expense' thing you've got going on here
Reply 4 of 8, by plasticfactory
RetroPCCupboard wrote on Yesterday, 18:46:
I suppose that isn't bad feedback! I bought a NOS AOpen BG08
Mike_ wrote on Yesterday, 19:11:
The plan was to do an XP build next, but the main issue with this is that I happen to have the CPU and Voodoo 5 already 😀
Fish3r wrote on Yesterday, 19:20:
I strongly considered this and ultimately picked the Coppermine because I like the Slot 1.
I was really close to the Tualatin and wound up going for the Coppermine because I like the Slot 1 form factor. Hopefully I don't regret this.
Reply 5 of 8, by wbahnassi
I would swap the AWE64 Gold for an AWE32 with real OPL3 for DOS. I don't think there is anything to gain from the AWE64 DOS-wise compared to AWE32. An AWE32 with real OPL3 would sound nicer for DOS games with FM music.
Turbo XT 12MHz, EGA, MFM HDD
Intel 386 DX-33, Speedstar 24X, SB 1.5, 1x CD
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
IBM BlueLightning 100MHz, CL5428, SB16, 4x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, RTX2060
Reply 6 of 8, by RetroPCCupboard
Tualatin supporting motherboards with ISA and AGP are quite hard to come by though. I have one with AGP but no ISA and one with ISA but no AGP.
Reply 7 of 8, by NeoG_
The voodoo2 SLI setup is probably wasted here as the voodoo5 will run anything in win98 better and DOS games won't take advantage of SLI - A voodoo5 and Voodoo1 would be a better combo IMO. If not a V1, a single V2 is more than enough for DOS era games once you apply compatibility patches.
98/DOS Rig: BabyAT AladdinV, K6-2+/550, V3 2000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, SB16-SCSI, PicoGUS, WP32 McCake, iNFRA CD, ZIP100
XP Rig: Lian Li PC-10 ATX, Gigabyte X38-DQ6, Core2Duo E6850, ATi HD5870, 2GB DDR2, 2TB HDD, X-Fi XtremeGamer
Reply 8 of 8, by such
I had issues trying to run Lithtech games on a similar setup. For some hot Shogo action I'd say not recommended?
