First post, by rwGast
Its been 26 years since I have fiddled around with IDE and DOS boot disks. Im not sure if i have a pile of bad CD-ROM drives, or im doing something wrong.
On IDE channel 1 I have a CD-ROM, and channel 2 has a zip disk and tape drive (these are both set to cable select). I have tried the CD-ROM as cable select and master. The bios sees all ide drives fine. The boot disk detects the CD-ROM and installs mscdex. I can switch to D: but when I try to DIR, the CD drive doesnt light up or spin and i get this error.
https://lh3.googleusercontent.com/d/1PI-iorGj … JZjirObU13q0sSd
