First post, by emodel
hi
Some games are too slow, some are too fast.
I'm talking about the way the game was meant to be, not emulation speed, which is accurate.
Some racing games especially, are too fast to me.
I Mame I can use the "screen refresh rate" to change this, it works superb.
In dosbox, the only way i found is to use yhkwong build with vsync patch, and change this to lower frequency (like 45hz).
Lowering cpu cycles is not an option as game speed changes depending on scenes complexity.
So would it be possible to add such a "screen refresh rate" option to dosbox ?
thanks
Reply 1 of 11, by eL_PuSHeR
Can't you do this in your graphics card control panel? I think you can force refresh rates there.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 11, by emodel
Mmm, I certainly would not like to do this, it would be very tedious.
Moreover it's not possible I guess, as most monitors only support 60hz (or more).
Latest dosbox cvs on windows xp sp3
Reply 3 of 11, by Qbix
Rank DOSBox Author
DOSBox Author
have you tried the cvs of dosbox ? (maybe try a different chipset or so)
however our refresh rate calculations are pretty accurate as far as I know
Water flows down the stream
Reply 4 of 11, by emodel
Hi Qbix
I downloaded latest aep compile. What should I change there ?
I dont see any parameter regarding refresh rate or so (?)
Oh maybe my question wasn't clear enough.
What I meant is that some games are too slow or fast TO MY TASTE 😉
So I'm looking for a solution to change gamespeed.
thanks
Reply 5 of 11, by ADDiCT
Another very, very strange post...
You're using the wrong tool for the job, so to say. Changing the refresh rate in emulators is not an adequate tools for speed control. Read this for more info.
I don't understand why you would change the emulation speed in MAME, as MAME is quite accurate in emulating the correct speed of emulated games, no matter what the actual screen refresh rate is (emulation accuracy is one of MAME's basic premises). In MAME, you can change frameskip with F8/F9, and "throttle" emulation speed with F10 (speed up the emulation, that is). I don't think there are any other options for changing emulation speed in MAME, so your changing of the refresh rate is nothing more than a "dirty workaround". Other emulators may have more options for changing emulation speed (like slowing down the emulation to make hard passages in games easier).
Anyway, the correct tools for speed control in DOSBox are "cycles" and "core". For slow machines, you can increase the emulation speed by using "frameskip". The DOSBox readme explains all commands in detail.
Reply 6 of 11, by Qbix
Rank DOSBox Author
DOSBox Author
sorry emodel. dosbox isn't a cheat machine 😀
Reply 7 of 11, by emodel
OK, thanks Qbix. I'll stick with builds which have vsync, and mame which IS a cheat machine, it seems (It is just giving options to the user, but call it what you want).
Cheers.
Reply 8 of 11, by Qbix
Rank DOSBox Author
DOSBox Author
it was a nice term for it I thought.
Reply 9 of 11, by ih8registrations
Sticking with vsync doesn't gain you anything for this purpose, it's not tied to system speed like in mame.
Reply 10 of 11, by emodel
Ah ok, so it's maybe just MY dosbox version which slows games down when I reduce it.
How cool ! 😀
Reply 11 of 11, by ih8registrations
Only if a game's timing were based on refresh rate, otherwise placebo.
