Cannot copy onto floppy drive
Reply 40 of 91, by DaveDDS
Ok, I just fired up XP (SP3) in a virtual machine, went to where DOSBOOT.ZIP is located:
- Double click DOSBOOT.ZIP (open display of files in DOSBOOT.ZIP)
- Right-click DSKWRITE.EXE -> Copy
- Go up a level (back to where I can see DOSBOOT.ZIP)
- Right-CLick where no file gets selected -> Paste (DSKWRITE.EXE appears in this directory)
- Double-click DSKWRITE.EXE (DSKWRITE runs and prompts you to select an image)
https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChw can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small filetransfer(w/o netSW)via Lan/Lpt/Com
Reply 42 of 91, by Im from Windows
DaveDDS wrote on 2026-07-04, 13:55:
When posting screenshots of files like this when seeking help with them, it's worth turning on the display of extensions and sizes (things I always keep turned on in my systems)
Reply 43 of 91, by Im from Windows
DaveDDS wrote on 2026-07-04, 14:07:
I'm not sure exactly what you are doing ... my DOSBOOT.ZIP archive contains a bunch of DOS boot disk images, as well as some too […]
Im from Windows wrote on 2026-07-04, 13:49:
I just downloaded it thanks! after abstracting the file to my chosen folder (compressed zipped files) it looks identical to the other one that I downloaded before in the above screenshots
I'm not sure exactly what you are doing ... my DOSBOOT.ZIP archive contains a bunch of DOS boot disk images, as well as some tools for working with them:
W:\SITE\DNLD> ZDIR DOSBOOT.ZIP
2026-04-24 16:49:04 8362 _DOSBOOT.TXT
2026-04-24 16:49:04 1474560 CALDERA.IMG
2026-04-24 16:49:04 17408 DSKWRITE.EXE
2026-04-24 16:49:04 6776 FDI.COM
2026-04-24 16:49:04 3234 FDI2ISO.COM
2026-04-24 16:49:04 1474560 FREEDOS.IMG
2026-04-24 16:49:04 327680 MSDOS112.IMG
2026-04-24 16:49:04 368640 MSDOS211.IMG
2026-04-24 16:49:04 1474560 MSDOS331.IMG
2026-04-24 16:49:04 1474560 MSDOS400.IMG
2026-04-24 16:49:04 1474560 MSDOS500.IMG
2026-04-24 16:49:04 1474560 MSDOS622.IMG
2026-04-24 16:49:04 163840 PCDOS090.IMG
2026-04-24 16:49:04 163840 PCDOS100.IMG
2026-04-24 16:49:04 163840 PCDOS110.IMG
2026-04-24 16:49:04 368640 PCDOS210.IMG
2026-04-24 16:49:04 368640 PCDOS300.IMG
2026-04-24 16:49:04 1474560 PCDOS330.IMG
2026-04-24 16:49:04 1474560 PCDOS71.IMG
2026-04-24 16:49:04 1474560 PTSDOS.IMG
2026-04-24 16:49:04 3302 XDISK.COM
W:\SITE\DNLD>
The one you want is DSKWRITE.EXE
I downloaded and installed "DOSBOOT" there was no .img or .exe to it or anything. though it downloaded as a zip so it was "DOSBOOT.ZIP" I downloaded
Reply 44 of 91, by Im from Windows
DaveDDS wrote on 2026-07-04, 14:28:
Ok, I just fired up XP (SP3) in a virtual machine, went to where DOSBOOT.ZIP is located: […]
It runs the command prompt for 1/2 a second then closes down. Nothing further
Reply 45 of 91, by DaveDDS
Im from Windows wrote on 2026-07-04, 14:54:
DOSBOOT doesn't "install" - it's just an archive of a collection of files (which happens to include DSKWRITE.EXE and a bunch of .IMGs for various DOS versions)
I really don't know what you did
Just to confirm, I've just downloaded DOSBOOT.ZIP from my site to my R:\ drive and double-clicked to open it - see attached screenshot.
Reply 46 of 91, by DaveDDS
Im from Windows wrote on 2026-07-04, 14:58:
Then I "dragged" DSKWRITE.EXE from the right window showing the content of DOSBOOT.ZIP to the left window showing R:\ (my RamDrive)
and double-clicked DSKWRITE.EXE in the left window.
Reply 47 of 91, by DaveDDS
Im from Windows wrote on 2026-07-04, 14:51:
When asking for help manipulating files, it's a good idea to accurately describe those files - this include things like exact name and extension, and exact size.
To always display extensions, you go to ControlPanel -> FolderOptions -- and uncheck "Hide extensions for known file types"
In XP, right-click the "Title" bar (which will at least say "Name") and you will get a list of additional information you can choose to display (or not).
Reply 48 of 91, by Im from Windows
DaveDDS wrote on 2026-07-04, 15:46:
DOSBOOT doesn't "install" - it's just an archive of a collection of files (which happens to include DSKWRITE.EXE and a bunch of […]
Maybe I have downloaded the wrong file!
Showing you a screen shot of it
Reply 49 of 91, by Im from Windows
DaveDDS wrote on 2026-07-04, 16:03:
defently have a different dowload as I dont have DSKWRITE.EXE present
Reply 50 of 91, by Im from Windows
DaveDDS wrote on 2026-07-04, 16:15:
When asking for help manipulating files, it's a good idea to accurately describe those files - this include things like exact na […]
The 2 missing from mine to yours are
Display the contents of a system folder
Display the full patch in a title bar
Is this what you mean?
Reply 51 of 91, by Im from Windows
Im from Windows wrote on 2026-07-04, 14:49:
OK I selected the write to disk at the bottom of the drop down menu of Disk Am I good to go then? Thanks […]
NeoG_ wrote on 2026-07-04, 13:55:
Im from Windows wrote on 2026-07-04, 13:52:
There are 4 options showing a disk. again please see attachment
The word "Disk", in the top menu
Thanks
So I have given it a go!
Booted the computer with the "win98 boot disk" in the A drive
Reads the disk but dose not seam to do a lot
Something indicates that i should have the "win98 insulation CD" in the D drive. When infact it is in the E drive instead. Cant do a screen shot out side of windows (if anyone knows how to do it then I would like to know) so did a video instead
https://www.youtube.com/watch?v=So73Km0VsJE
Reply 52 of 91, by NeoG_
Im from Windows wrote on 2026-07-05, 11:29:
How many cd/dvd drives does the computer have?
It was nice of you to narrate the video because it's too blurry to read
98/DOS Rig: BabyAT AladdinV, K6-2+/550, V3 2000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, SB16-SCSI, PicoGUS, WP32 McCake, iNFRA CD, ZIP100
XP Rig: Lian Li PC-10 ATX, Gigabyte X38-DQ6, Core2Duo E6850, ATi HD5870, 2GB DDR2, 2TB HDD, X-Fi XtremeGamer
Reply 53 of 91, by Im from Windows
NeoG_ wrote on 2026-07-05, 12:19:
I have as followed
A:\ floppy
C:\ HDD
F:\ HDD (2nd partision)
D:\ DVD IDE (door button broken, need a long pin to open it!)
E:\ CD ROM SATA
The camera is not great and dose not like the darkness
Reply 54 of 91, by NeoG_
Yes I agree then that the startup disc is looking for the CD in the first drive. You can instead use the boot to command prompt with cd-rom support option, then go to drive E:, type"setup" and press enter to start the windows 98 installation that way
Reply 55 of 91, by Im from Windows
NeoG_ wrote on 2026-07-05, 12:46:
It gave me the A:\ command
I have type C:\ then enter, then D:\ then enter and it dose not work!
Reply 56 of 91, by NeoG_
Im from Windows wrote on 2026-07-05, 12:54:
What does that mean? What message is it giving you?
Reply 57 of 91, by Im from Windows
NeoG_ wrote on 2026-07-05, 12:56:
I just reboot it and tried again
At the A:\ command. I type C:\ or E:\ then enter and it says "invalid drive specification"
However I type D:\ then enter key and it changes from A:\ to D:\
It is almost as it will not except any other drive to install from the the D drive
Reply 58 of 91, by DaveDDS
Im from Windows wrote on 2026-07-05, 10:43:
... defently have a different dowload as I dont have DSKWRITE.EXE present
Look to me that it's the right archive, and you DO have "DSKWRITE.EXE"
This goes back to how I suggested configuring Winblows to show all the information about files when you are trying to get help.
I'd bet that you have NOT unchecked "hide extensions for known file types" in folder options.
Winblows recognized the extension ".EXE", so it's not displaying it! (why would anyone want to know that a file is a program)
If you tweak the folder options do as I suggested - I'm sure it will magically start showing "DSKWRITE.EXE"
If you *really* agree with MS and don't think users should be able to tell what's actually on their systems, you could:
Drag "DSKWRITE" out of the ZIP file and put it somewhere in a normal directory.
Either: Open the command prompt, then CD to where you put it and do "DIR" - this should show extensions
Or: right-click on "DSKWRITE" and do "make shortcut"
then - right-click the shortcut and do "Properties", you'll see that it links to DSKWRITE.EXE
Reply 59 of 91, by DaveDDS
Im from Windows wrote on 2026-07-05, 10:47:
... The 2 missing from mine to yours are Display the contents of a system folder Display the full patch in a title bar Is this w […]
I didn't see SIZE in your screen captures - actually now that I think of it you probably have to do "View" -> "Details" or something like that to actually get sizes even if they are turned on.
