What are your favourite DOS utilities?
Reply 40 of 52, by aVd
NFORMAT! tool, that I mentioned earlier here
aVd wrote on 2026-06-20, 05:31:
NFORMAT! - this tool helped me to save a tons of "damaged" floppy diskettes with magnetically "bad sectors".
has all the settings needed for floppy disks "overburning" and formatting in non-standard formats:
The attachment NFORMAT_settings.jpg is no longer available
It has a super simple and fast TUI interface and it does its job perfectly fine. The only drawback - it comes without build-in standard DOS format profiles for 5.25" diskette drives, but this could be easily corrected by adding user profiles with all the settings needed.
I like the quieter planets, this one became pretty noisy 😀
Reply 41 of 52, by zyzzle
Nformat was great along with DaveDDS Imagedisk utility of course. Nformat was easiest to use and it allowed great modifications to all the lax, standard values to increase capacity.
But there were also a couple more oddballs like 188.exe which claimed to be able to format a 1.44 floppy to 1.88M. I never got it to work. And there was the Microsoft DMF standard which put 1.68M on a 1.44M floppy using 21 sectors per track. I remember Win 95 was shipped on DMF 1.68M floppies.
And the author of 2M, Ciriaco García de Celis, with whom I communicated fondly with back in the 1993-95 period, also released a utility called 765debug with the 2M package which allowed one to test floppy drives to very fine detail and standards of precision.
Reply 42 of 52, by kingcake
zyzzle wrote on 2026-07-07, 01:38:
interesting I will have to look for this.
winimage could do some weird high capacity formats. but it's a windows app, obviously.
Reply 43 of 52, by aVd
Hi, @zyzzle,
This m$ DMF format can be easily created with tools like NFORMAT! or ImageDisk (IMD) and WinImage also supports it. DMF main format parameters can be found in wikipedia article and also here: https://winimage.com/wimushlp/wini1a1y.htm
I found 765DEBUG version 5.0 and its source code here: http://ftp.oldskool.org/pub/drivers/Central%2 … bleuge/765debug
Thanks for mentioning this tool.
It will be even nicer, if download links or URLs are given, when something not so popular is suggested.
Reply 44 of 52, by zyzzle
aVd wrote on 2026-07-08, 04:29:
Thanks for your link to the newest version of 765debug. I still had the old ver. 4.0 included with 2MF, didn't even know a 5.0 had been released, so thanks for that and even the source code. (I almost posted the v 4.0 for reference to my post, but it's now obsolete with your find).
Reply 45 of 52, by OzzFan
kingcake wrote on 2026-07-06, 03:31:
Pretty solid list. I'll mod it a bit: […]
OzzFan wrote on 2026-07-03, 02:46:
My favorite DOS utilities are: […]
Debug (MS/PC DOS)
SpinRite (GRC)
Speedisk (Norton Utlities)
Speedsys
Quarterdeck Manifest
PKzip
Undelete/Erase Protect (Central Point Tools / Norton Utilities)
Debug (MS/PC DOS)
SpinRite 6.1 R4 (GRC)
Quarterdeck QEMM (Manifest comes with it)
IDEinfo (shows correct CHS for connected IDE drives even if bios is not set right/at all)
cachechk
IMD (good for testing/cleaning/aligning floppy drives and basic imaging)
ctmouse (my go to universal mouse driver for dos)
nansi.sys (ansi text speed boos + uses less memory)
videcdd.sys (my go to universal ide cd rom driver for dos)
mtcp
chkcpu
pro com plus
You bring up a couple other good ones that I forgot to mention: cachechk and chkcpu.
Reply 46 of 52, by fenriswolf039
yeah... XTree Gold
Reply 47 of 52, by ntalaec
Thanks for all your suggestions.
I've added a few more to the first post:
DEVLOAD (load drivers from command line)
http://cd.textfiles.com/somuch/smmodem/UTILS/DEVLOD18.ZIP (older version, seems to work better than newer one)
MicroWeb DOS web browser (web browser for 8088; can't do HTTPS)
https://github.com/jhhoward/MicroWeb
V (text file viewer)
https://discmaster.textfiles.com/file/28642/V … /view/v26tk.lzh
Xpdf (utilities to extract images and text from PDF files)
https://www.ibiblio.org/pub/micro/pc-stuff/fr … df/xpdf303b.zip
Reply 48 of 52, by aVd
"ZDir" was mentioned here: Re: What are your favourite DOS utilities?
But which one? I know of two different ZDIR DOS utilities:
ZDir - directory lister by Chris Kirmse.
ZDIR - list/touch (update timestamp) files within .zip by our fellow forum member Dave Dunfield (@DaveDDS).
Reply 49 of 52, by ntalaec
aVd wrote on 2026-08-03, 08:09:
"ZDir" was mentioned here: Re: What are your favourite DOS utilities? […]
I think it should be the first one.
I have added two more utilities to first post:
XMSDSK (RAMdisk that can be resized and unloaded; includes SETXMSTO to use > 64 MB of RAM in MS-DOS 6.22)
https://ftp.zx.net.nz/pub/mirror/simtel.net/p … sk/furd19_i.zip
NoteTaker (TSR with popup window to write notes; text mode only)
https://archive.org/download/SharewareCdrom19 … 1A%2FNTAKER.ZIP
Reply 50 of 52, by DaveDDS
... ZDIR - list/touch (update timestamp) files within .zip by our fellow forum member Dave Dunfield (@DaveDDS).
I doubt many people know about (or would use) my ZDIR ... it came into existence purely because I historically like to set the TIMEstamp of my packages I distribute to the version number of that package (eg: Micre-C/PC v3.23 - the files are have times: 03:23a) - and doing more and more under DosBox these days, DosBox does not support INT 21h AX=5701h (touch)
So I researched .ZIP format and created a tool to be able to "patch" .ZIPs to have timestamps I wanted on certain files - while I was at it, I made it do some things I thought "nice" to easily list the content of a .ZIP:
ZipDIRectory
use: ZDIR zipfile[.ZIP] [pattern][=[yr-mo-dy]-[hr:mi:se]]... [options]
Opts: -B Bare (no times/sizes shown)
-C show Compressed size
-D don't show main Directory entries
-F show individual File entries
-N show Names only (no path)
-Ofile[.ZIP] set Output file (only if) [%TEMP%_ZDIR_.ZIP]
-R don't Replace original ZIP ( =yr...) (keep ^^)
-S show Summary
-P[n] Page [24]lines (press SPACE to proceed, ESC to exit)
-W[col]] Wide (bare in columns [13])
-Q Quiet (no output)
Displays the content of a .ZIP in {directory format}
pattern = file match pattern (may contain '*','?'): *=All *.*=MustHave'.'
shows original DOS timestamps (Windows tries to adjust for DST)
If =yr-mo-dy-hr:mi:se those values in pattern-file timestamps will be changed
(TOUCHed) * =skip but don't change. If first seperator is ':', only time
is changed (not date). Some OSs (Windows) don't accept = (use "pattern=...")
But ... speaking of DIR listing tools, the one I use all the time is XDIR:
use:    XDIR [filespec] [options]
opts: /2 24 hour time
/A[+-]adehrs File must have Attributes ('e' =accept Every)
/B Bare format
/C Compact format (default with /O)
/E show sEconds
/F Files only (no dirs) in list (default with /SCB)
/L use Lower case
/M show Memory use
/N No commas
/S list Subdirs
/T directories Trail filenames
/U no sUmmary
/W Wide format
/O[-!]o list in Order ('-' = reverse)
o: 'D'ate, 'E'xtension, 'N'ame, 'S'ize (/C unless '!')
Wildcards work like they do in UNIX, ie: '.' has so special meaning:
use '*' for ALL files, '*.*' means name must contain '.'
Dave Dunfield - 2026/2/8
No fancy colors etc. just a simple compact output:
> XDIR/sc R:\TST
26-01-01 3:04a 64 R:\TST\D1\A1.TXT
26-05-01 4:02a 128 R:\TST\D1\A2.TXT
26-08-03 6:16a 192 R:\TST\D2\B1.TXT
26-01-02 3:04a 256 R:\TST\D2\B2.TXT
Total: 4 Files(s) 640 bytes.
It's not obvious from the above description, but /O(rder) works "globally" on ALL files in the listing (most DIRs can only /Order within single directory):
> XDIR/scod R:\TST
What's the last .C file I was working on in this tree? XDIR/scod *.C
What's the oldest .H ""? XDIR/sco-d *.H
What's the biggest file in this tree? XDIR/scos
What's the smallest ""? XDIR/sco-s
https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChw can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small filetransfer(w/o netSW)via Lan/Lpt/Com
Reply 52 of 52, by SantaCruzReplogle
QEdit
