First post, by stanwebber
i'm out of my element...it's been 30yrs since i installed one of these things. i got 2 identical 3.5" 1.44mb floppy drives that were known to work when they were removed however many decades ago. i installed 1 and got nothing: no lights, no sound. i set drive a to 3.5" 1.44mb in the bios and booted into linux, but was not able to see the drive. i swapped in the other identical floppy drive and got the same result.
are both floppy drives doa? should i see any lights or hear any sounds when the pc first boots up. it's been so long i can't remember. does the floppy cable have to be in the right orientation or connected at all for the drive to show signs of life?
the single drive floppy cable i have is round with no pins blocked out. both connectors have a notch on 1 side like an ide cable and pin 1 is indicated. my motherboard's floppy socket is keyed, but i don't know if it matters which end of the floppy cable to plug in since they are indistinguishable. the floppy drive has bare pins and no socket. i oriented pin 1 on the left as you are looking at the back of the installed drive (the connector notch is on the bottom).
Reply 1 of 8, by tehsiggi
Not sure what board we're talking about, but you can disabled floppy drives in the BIOS, incl. the floppy drive controller. The latter can be disabled and you can still configure floppy drives - don't ask me why. First thing I do on boards that will not get one. So check the bios settings again for anything obvious.
From my memory, if you insert the floppy cable the wrong way, the floppy drive LED is ON all the time and it doesn't work.
Normally, if the bios floppy is enabled, the OS should see it. Even if there is no physical drive attached.
AGP Card Real Power Consumption
AGP Power monitor - diagnostic hardware tool
Graphics card repair collection
Reply 2 of 8, by akimmet
A floppy drive plugged into power only will not show any signs of life.
At the moment, I suspect the problem lies with configuration or cabling, not the drives.
Reply 3 of 8, by stanwebber
tehsiggi, you nailed it! drive a was assigned in the bios, but the floppy controller was disabled. the drive shows absolutely no signs of life until you actually perform a read/write access on a floppy. somehow i remembered it being more visceral.
Reply 4 of 8, by DaveDDS
Does the cable have a "twist" near one end? (see attached pic)
If not, the drive will not work as A:
When IBM designed the PC, they didn't think users were smart enough to change drive jumpers, and didn't want their dealers to have to carry two different drives (A: and B:)
So they came up which this twisted cable which passed strait through to drive B: (is there were a drive B: connector in the pic, it would be just BEFORE the twist one the long end of the cable side.
The twist moves some signals so that the drive A: select appears in the drive B: position at the end of the cable (After the twist)
PC        DriveB:   DriveA:
This means BOTH drives on the PC have to be jumpered as the second drive (1 if 0,1,2,3 or 2 if 1,2,3,4)
If you don't have the twist, your drive will appear as drive B: on the PC
Note that some mainboards don't even support drive B:
If you are lucky your BIOS might have a "swap" floppy drive option, which will let you use a drive (jumpered as 2nd drive)
on an untwisted cable as drive A:
Try disabling drive A: (set to NONE) in BIOS and set up for drive B: - depending on BIOS it might "test" it at startup which would cause brief activity.
If you cable does have the twist - it should work "as is" check that drives are jumpered as 2nd drive.
https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChw can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small filetransfer(w/o netSW)via Lan/Lpt/Com
Reply 5 of 8, by DaveDDS
stanwebber wrote on 2026-07-07, 17:52:
If you have the ability to run DOS, you could use ImageDisk to test floppy drives - IMD accesses the drive(s) directly (not through DOS) - I normally keep the drives set to "none" on my IMD system (to avoid other stuff possibly messing with them)
But... on most more modern (that the 5150) boards, the FDC is part of a large system chip - an that portion of the chip might be disableable in BIOS (so do check that it's enabled)
Reply 6 of 8, by tehsiggi
Some boards have an option called "Boot up floppy seek" - if it's off, it's not doing anything during boot. If on, you get the usual seeking noise on POST.
Reply 7 of 8, by stanwebber
the cable is round. i assume there's a twist as drive a: is configured and accessible after i enabled the fdc controller. it was just confusing without the middle connector or blocked out pins.
ah, boot up floppy seek is what i remember back in the day. yeah, i'm leaving that off.
Reply 8 of 8, by DaveDDS
stanwebber wrote on 2026-07-08, 13:05:
Glad you got it working.
Boot up floppy seek does serve a purpose on AT+ - used to detect 40 or 80 track drive.
Home head (step in till Track0)
Seek out 50 or so tracks (enough to overflow a 40-track drive)
Seek in, counting till Track0
If <40 - report drive error, if <50 - drive is 40-track (360k), if 50 - driver is 80 track (1.2m) - if >50 report drive error!
Later on when 3.5" became common (all 80 track) this wasn't as useful which is why you could turn it OFF.
