Reply 7820 of 7840, by leileilol
- l33t++
I beat Deus Ex again, but this time it's the Playstation 2 version, and on Realistic difficulty
- No coronas nor detail textures
- Overbrights and the lightmap looks shifted up so it's generally brighter. The only dark place are the catacombs and the blown up osgoods. There is a dither table used and you will love it
- A lot of texture detail was dinged down a notch for texture cache's sake, but also some areas were broken up a bit (i.e. the new gate at the dock) to prevent overdraw. Most big maps are split into 2 or 3, with some elbow hallways for loading zones
- Characters are higher poly smoother (skeletal rework) but their lipsync is simplified to just one frame of interpolated mouth open. Their polygonal teeth go unused (revealed in holograms)
- Supports keyboard & mouse but the binds are weird.
- The Image vault sorting seems broken, if you collect Walton Simons' image you will be jumpscared by a naked walton simons every time
- Music changes - while most songs get monofied (memory reasons), a couple songs have some broken string pads (Hell's Kitchen) and the Underworld bar music seem to be original pre-tracked mixes. Lucky Money and Paris bars did get completely changed though
- the fun glitch of tranq'ing a mech before their fight conversation to avoid a fight is sadly fixed
- Still typos. "Cypto", "HANGER", "MISSLE SILO"
