First post, by RayeR
Hi, I got this MB https://theretroweb.com/motherboards/s/qdi-p6 … -advance-5-133e from a scrap with PIII/550MHz and testing it. Visually it's in a good conditions, no scratches, etc.
But the 1st problem I had after power on was the PS/2 keyboard. For some reason it doesn't work with my Labtec Y-SAM64 PS/2 kbd that I usually use for testing (it rarely make some keypress so I can enter SETUP but cannot set much more). This MB has 2 onboard PS/2 connectors for KB and mouse. I measured all PS/2 pins for shorts/connections, checked 5V voltage, all components in signal path (LC filters, 4k7 pull-up R-network and serial 0R-network) and it was OK so I decided that it could be partially damaged SuperIO chip W83977EF-AW e.g. by ESD. I had some spare one so I replaced it but still the same!
So I tried another keyboard Chicony KB-2971 and it worked. WTF? but well maybe some strange incompatability...
But wait, not done yet. Futher madness started when I plugged PS/2 mouse (1st I tried MS intellimouse optical USB in PS/2 adapter) in PS/2 mouse port. It caused that keyboard became nearly irresponsive. ~95% key hits did nothing. Even problems in SETUP or plain DOS before loading any mouse driver. When I pulled mouse out KB started work normally. I also tried to load CTMOUSE driver in autoexec, then the keyboard worked until I made 1st move with mouse. The mouse doesn't work normally - programs that use mouse on start just show mouse cursor running to corner to the right or down or cursor jumps like crazy - totally incrontrollabe with mouse...
Then I took out the scope to look at KBCLD and KBDATA waveforms. Without mouse attached it looks normally. Both in H level at idle with short data/clk passed when a key pressed. But with attached mouse a strange thing happen. KBCLK went L with only a short pulses to H at frequency 22,2Hz and H duration ~140us. (it was noted to be a inhibit state - superIO can do this by pulling CLK low when it cannot read out incoming data) This happened quite soon in POST stage of HDD detection and remains under plain DOS. When CTMOUSE was loaded the KBCLK went idle (H) but only until the 1st mouse move - then again KBCLK went L with only a short pulses to H but now with frequency 200Hz. I found a correlation with pulsed on IRQ12 line on ISA slot that should be linked with PS/2 port, the same frequency but H duration was only ~40us.
I consulted with AI but it gave a lot of misleading statements. It belives that it's a problem of VT82C596B southbridge that was unable properly read out both KB and mouse at high data rate. It suggested me some shot code that is capable to reset keyboard in working state (it makes KBCLK going idle H) until mouse moves again.
;PS/2 keyboard reset
.MODEL TINY
.CODE
ORG 100h
STARTUPCODE
CLI
WAIT1: IN AL, 64h
TEST AL, 02h
JNZ WAIT1
MOV AL, 60h
OUT 64h, AL
WAIT2: IN AL, 64h
TEST AL, 02h
JNZ WAIT2
MOV AL,61h
OUT 60h, AL
STI
INT 20h
END
It told me that USB intellimouse is hardcoded to spit data at high 200Hz rate that VT82C596B can't handle and suggested to use some older native PS/2 mouse that can be programmed to lower data rate. So I found and tested Genius Mouse NetScroll Optical PS/2. There was really some change in behavior. When power on the MB with KB and mouse attached the mouse light up immediate after power on and I can see pulses at KBCLK with 200Hz rate but strangely the keyboard was relative responsive so I can type with only rare misses. I loaded mouse driver and it swithed data rate to 80Hz and keeps KBCLK idle (H) so keyboard typing was OK but mouse still doesn't work properly - cursor flew instantly to corner or sceen edge. After some messing with mouse it switched data rate to 200Hz and pulses at KBCLK appeared again. (I checked multiple times but there's no any electrical short or connections between KBDATA, KBCLK, MDATA, MCLK).
I never seen such behavior before but I mostly deal with intel chipset MBs. I know that VIA and Ali had a lot of weird quirks, so can't say this would be normal on some crappy chipsets... Or maybe there could be some broken connection between Super IO and Southbridge or Southbridge and Northbrige that could cause this?
As a last try I booted Hiren's CD and tried MiniXP and Linux/Gparted. Under MiniXP the mouse cursor was frozen in the middle of sceen, in control panel PS/2 mouse was detected. Under Linux I had jumpy cursor like under DOS and received lost sync messages in console, see below. I also tried to plug USB mouse in USB port but even USB enabled in SETUP anb UHCI is detected the USB mouse was not detected neither in MiniXP nor Linux. USB ports provide at least 5V power. So maybe also USB ports are dead...
Reply 1 of 22, by rasz_pl
RayeR wrote on 2026-07-05, 21:34:
sigrok has PS/2 decoder
looking at sample capture now https://github.com/vpalatin/sigrok-dumps/blob … board_asdfgh.sr decoder doesnt support binary output 😐 so have to go CLI route. Hmm how did that work I already forgot 😐 but I did write enough of it down to quickly catch up https://github.com/raszpl/sigrok-disk#example-invocation
sigrok-cli.exe -D -P ps2  --show
Long name: PS/2
Description: PS/2 keyboard/mouse interface.
License: gplv2+
Possible decoder input IDs:
- logic
Possible decoder output IDs:
None.
Decoder tags:
- PC
Annotation classes:
- bit: Bit
- start-bit: Start bit
- stop-bit: Stop bit
- parity-ok: Parity OK bit
- parity-err: Parity error bit
- data-bit: Data bit
- word: Word
Annotation rows:
- bits (Bits): bit
- fields (Fields): start-bit, stop-bit, parity-ok, parity-err, data-bit, word
Binary classes:
None.
Required channels:
- clk (Clock): Clock line
- data (Data): Data line
https://github.com/vpalatin/sigrok-dumps/blob … board_asdfgh.sr:
sigrok-cli.exe -D -i  ps2_keyboard_asdfgh.sr  --show
Samplerate: 24000000
Channels: 8
- D0: logic
- D1: logic
- Data: logic
- Clock: logic
- D4: logic
- D5: logic
- D6: logic
- D7: logic
Logic unitsize: 1
Logic sample count: 57458933
so we need to tell it data and clock channel names, lets see all 'fields'
sigrok-cli.exe -D -i  ps2_keyboard_asdfgh.sr   -P ps2:data=Data:clk=Clock  -A ps2=fields
ps2-1: Start bit
ps2-1: Data: 1c
ps2-1: Parity OK
ps2-1: Stop bit
ps2-1: Start bit
This decoder is very basic 🙁, barely 100 lines of python, and doesnt decode above PHY layer but its still better than looking at scope screen.
I would take captures from both keyboards for comparison.
I consulted with AI
I love a good glue on pizza session myself!
you did look at the signals, did mouse really send 200 reports/second? afaik no ps2 mice did that by default, not that it would be a problem to begin with
this sends KBC_CMD_60_WRITE_CONFIG and sets https://github.com/raszpl/Zenith_ZBIOS/blob/1 … %203.2C.h#L1971
enum __bitmask __bin __lzero IO_Port_64h_KBC_CMD_WRITE_CONFIG : unsigned __int8
KBC_CFG_KEYBOARD_INT_ENABLE = 0b00000001,
KBC_CFG_MOUSE_INT_ENABLE = 0b00000010,
KBC_CFG_SYSTEM_FLAG = 0b00000100, ///< Bit2 1=System Passed POST, 0=Cold Reset
KBC_CFG_INHIBIT_OVERRIDE = 0b00001000, ///< Bit3 1=Ignore Keyboard Lock Switch
KBC_CFG_KEYBOARD_DISABLE = 0b00010000,
KBC_CFG_MOUSE_DISABLE = 0b00100000,
KBC_CFG_TRANSLATE_Set2_to_Set1 = 0b01000000,
61h = 01100001 = reinit keyboard, disable mouse
super doubt, and even if true shoudnt be a problem
I would start by checking if keyboard and mouse get enough power, and grabbing ps2 captures for comparison
Reply 2 of 22, by Nexxen
Can you see "system monitor" in BIOS?
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- Bare metal ist krieg.
Reply 3 of 22, by rasz_pl
cheap board, might not have one
Im mainly thinking that green thing is a polyfuse on keyboard/mouse power and somehow was damaged to the point its not passing enough current now.
Reply 4 of 22, by Nexxen
rasz_pl wrote on 2026-07-06, 14:18:
I have 2 such boards.
I had issues with one because of the LM-80 chip failed to some extent and failed completely later.
The other one is my working base I'm using to solve the other's problem (cpu not working if Vcore is above 1.75V)
Maybe he should try another cpu with a 1.65V to be sure (just a wild guess).
If the LM-80 failed, the system monitor will not appear or not allow changes.
I had issues with PS2 as well, maybe it's not it but a fast check ain't make it worse 😀
Reply 5 of 22, by maxtherabbit
Yeah the symptoms scream inadequate power delivery. My money is on this
Reply 6 of 22, by weedeewee
maxtherabbit wrote on 2026-07-06, 15:15:
I concur.
Do not ask Why !
Reply 7 of 22, by RayeR
The PS/2 power lines for KB and mouse was one of the first I looked with scope-no visible voltage drops/ripple. Also data and clock lines looks fine, no distortion/slow edges/bad levels. Electrically it seems ok. There's no LM80 chip. I have another board with a bit older SB VIA VT82C586B and there both PS/2 mouse and KB (same I used here) works fine so it seem not be SB issue itself but maybe some broken trace between SB and SIO. I don't have PS/2 mouse protocol analyser but I used low level ps2 testing program and it also reported malformed/out of sync data.
Reply 8 of 22, by Nexxen
RayeR wrote on 2026-07-06, 21:54:
Can you post a hq pic of your board?
LM80 is in the upper right corner, U4. It is missing?
Reply 9 of 22, by RayeR
I'm away for some days so maybe I'm wrong about LM80. HW monitor page is present in bios but it maybe values from SIO... how it would be relevant to PS/2? I checked power lines with scope and DMM, hw monitor reported a bit off values like 13.x V instead real 12.2V.
Reply 10 of 22, by RayeR
Sorry for confusion, LM80 is populated on MB. I'll make a better photo without flash on daylight tomorrow...
Reply 11 of 22, by shevalier
I would replace the Array CN1 capacitor (C470 - 470pF).
Old Y-ceramics start to behave very strangely on signal lines with age.
This can cause very unpleasant effects.
From personal experience, with one keyboard, the motherboard doesn't boot, only beeps strangely.
With another, it works.
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
Reply 12 of 22, by RayeR
WTF, I desoldered that capacitor network and it works now, KB&mouse together (Labtec too).
BUT before I desoldered it I also pulled out the CPU before making new photo and then pushed it back. The same with DIMM. Unfortunatelly I didn't turn it on after photo before cap desolder so cannot identify the cause. I solder cap net back to the place and it still works!
I have a strong suspection that durig manipulation with CPU some bad solder joint might reconnect and link with cap is pure random. USB ports still seems doesn't work...
Reply 13 of 22, by Nexxen
RayeR wrote on 2026-07-10, 19:25:
Do you have a cpu with Vcore < 1.75v? In case try it.
Reply 14 of 22, by RayeR
I tested all with PIII/550/100/512k/2,0V.
I have PIII/733/133/1,65V but I cannot find my only one FC-PGA adapter. I found PPGA only and it doesn't work with this newer FC-PGA CPU.
Reply 15 of 22, by shevalier
My CUBX-L worked for a year without any problems, but then started malfunctioning for 3–4 days (accompanied by a beeping sound and an inability to start up).
After I let it ‘cool down’ a bit, it started working again.
This is a characteristic feature of cheap ceramic of capacitors.
As soon as they start to fail, their behaviour becomes unpredictable.
For example, they develop a resistance comparable to that of pull-up resistors.
Replace the ceramic capacitor with a C0G (NP0) and you’ll never have to worry about this problem again.
Any 4-capacitor array in white, pink or blue (definitely not yellow or brown) with a capacitance of 100–470 pF from any donor.
Reply 16 of 22, by RayeR
Maybe, but it is strange that I did not observed any distortion on PS/2 signal lines. I would expect that bad capacitor could do some bad to signal edges or levels, etc. Here's some osci from KB when it behaved badly (on mouse port it looked OK too)...
Reply 17 of 22, by Mike_
shevalier wrote on 2026-07-11, 07:26:
My CUBX-L worked for a year without any problems, but then started malfunctioning for 3–4 days (accompanied by a beeping sound a […]
That's quite suprising. I had thought that you don't need to worry about ceramic caps aging, and they'd last almost indefinitely like resistors.
Reply 18 of 22, by shevalier
Mike_ wrote on 2026-07-11, 12:15:
After all, it is an external interface that is often connected whilst the device is powered on.
It seems that voltage spikes are getting through, which damage the dielectric.
Reply 19 of 22, by RayeR
rasz_pl wrote on 2026-07-06, 07:04:
BTW not sure if I can imagine correctly what this mean but here in CZ I would say that AI pulled me on a cooked noodle - It's extremely good in generating a ton of bull$hits that looks pretty reasonable at first sight but a few hours later one get caught that it lead to nowhere, just explored a blind paths. But it's hard to find people with highly specialized level of knowledges to talk with (that even had a time to share it). OK, for some casual python coding it's not so bad...
