Toshiba 2805-s402 Ultimate retro gaming laptop
Reply 200 of 201, by grubypizza
MAZter wrote on 2026-07-14, 02:23:
grubypizza wrote on 2026-07-14, 02:02:
but not sure if this site is legit, I am trying to contact some sellers in China, but for now without success:(
There is little point in looking for the original hinges, as they are unlikely to last long after replacement due to the poor quality of the material.
For the Toshiba Satellite 5005-S504 (as example) I used steel hinges from a completely different model and brand; while it doesn't look perfect, everything works functionally.
I will try to get original hinges and reinforce them with aliminum or steel sheet from a can, maybe this will help a little, but if they will brake again I think I will do the same as you with matching hinge from other laptop model, if I may ask - hinges from what laptop model did you use?
Reply 201 of 201, by MAZter
grubypizza wrote on 2026-07-14, 02:32:
I don't remember exactly, maybe from Compaq 12XL126 / 1240 / 1200XL / 1800T with little adjustments using Dremel.
