SBEMU: Sound Blaster emulation on AC97
Reply 1920 of 1988, by shawnmos
crazii wrote on 2026-06-28, 06:23:
It seems a IO problem. e.g. INT13h error causing command.com not loaded properly. You may want to comment out your lines in CONF […]
shawnmos wrote on 2026-06-26, 19:00:
I am getting "The following file is missing or corrupted: Command.com" after loading JemmEx. I am using an Inspiron 2200 laptop with Intel 915 chipset and AC'97 audio. Any ideas?
You may want to comment out your lines in CONFIG.SYS, e.g. add REM before DEVICE=JEMMEX.EXE and other lines to find out which device driver is causing the problem.
Also disabling option ROMs and USB legacy supports in BIOS settings may help.
I assume you don't use VDPMI but JEMMEX, because the two programs are not compatible. So another options is try VDPMI, but no guarantee that it will work, I will post the link in the OP.
I get the error when loading JEMMEX regardless what else is loading in config.sys. I decided to give QEMM v9 a try as well but it just hangs. When I try to do the memory optimization feature of QEMM I end up getting the same command.com error. I tried using the JEMMEX /load command after booting and after it loads I get a drive not ready or general failure reading drive c (I can't remember which exactly). I'll take a look at the BIOS too but since it's a base model Dell I don't think there was much in the way of settings. SBEMU does work without JEMMEX and real mode, but I was trying to get Keen 4 working and I think it needs real mode.
Thanks for your help. I'll give the VDPMI version a try next.
Reply 1921 of 1988, by shawnmos
shawnmos wrote on 2026-07-02, 21:43:
I am getting this crash unfortunately
The attachment 20260702_192356.jpg is no longer available
Reply 1922 of 1988, by sergio_prado
I have the same problem with my Precision M70, which uses the same chipset. I’m no expert, but it seems JEMMEX messes up the communication between the system and the HDD on these older Dell laptops. I found a workaround: placing the XHDD caching driver after JEMMEX in config.sys.
http://optimizr.dyndns.org/dos/drivers.html
Reply 1923 of 1988, by RayeR
I observed similar behavior on my GB MB with P67 chipset. When the HDD is attached to SATA3 port it has some weird issues in V86 mode, I have special version of XHDD that resolve it. When the HDD is attached to SATA2 port it works OK. I have SATA in IDE compatible mode and USB legacy disabled.
Reply 1924 of 1988, by ntalaec
Thanks for this project!. I've been using the latest experimental build with VDPMI. Works better than the one with HDPMI in my computer (Intel Atom N280, 1 GB RAM, Intel HDA, MS-DOS 6.22).
This are the lines I use to load SBEMU:
DEVLOAD.COM VDPMI.EXE /EMS
SBEMU.EXE /I5 /T6 /O1 /VOL60 /K44100
This is my CONFIG.SYS:
DOS=HIGH,UMB
DEVICE=C:\DOS\SETVER.EXE
DEVICE=C:\DOS\HIMEM.SYS /TESTMEM:OFF
DEVICE=C:\UMBPCI\UMBPCI.SYS
DEVICEHIGH=C:\DOS\POWER.EXE ADV:MAX
COUNTRY=034,,C:\DOS\COUNTRY.SYS
DEVICEHIGH=C:\DOS\DISPLAY.SYS CON=(EGA,,1)
FILES=30
STACKS=9,256
I get some errors:
  • Loading VPDMI I get the following warning: 64K page frame unavailable. limited page frame size: 32K
    Running MEM shows 56.364K XMS in use and 4.096K total and free EMS memory, but most of games seem to work fine.
  • PC Speaker does not work in any game I've tried. Without SBEMU all work fine.
  • Visual Player 2.0 (MOD audio player) does not load and shows this error: ERROR: 8 Bit DMA not detected, please try again...
  • Disney's Aladdin plays fine but with corrupted graphics at the bottom of screen.
  • Links 386 Pro crashes with the following message.
    Spoiler
    386|DOS-Extender 4.1 -- Copyright (C) 1986-92 Phar Lap Software, Inc.
    Serial Number DE1-9163
    VDPMI Client32 "LINKS386.EXE" Protected Mode Exception: 0d, Error code: 00
    EAX:00000000 EBX:00001098 ECX:00001000 EDX:00020000 ESI:0050f804 EDI:00000c40
    EBP:00000c4c DS:00e7 ES:0107 GS:0107 FS:0107 CR2:00000000 VISR=0000
    SS:ESP:0107:0009d8ee CS:EIP:00ff:000005df EFLAGS:00210202 VM=0 IF=1 VIF=0 VIP=0
    DS: base: 0000ebd0 limit: 0000ffff ES: base: 00000000 limit: 000fffff
    SS: base: 00000000 limit: 000fffff CS: base: 00019460 limit: 0001ffff
    CS:EIP: 26 89 46 fc 67 a1 b8 1c 26 89 46 f8 26 89 4e f4
    SS:ESP: a5a501fe a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5
    VDPMI Server Exception: 0d, Error: 0014
    SS:ESP:0020:0000efc8 CS:EIP:0010:0050d1da EFLAGS:00210002 VM=0 IF=0 VIF=0 VIP=0
    SS: base: 008ff000 limit: 00524fff CS: base: 008ff000 limit: 00524fff
    CS:EIP(0002:000021da): cf 00 00 00 00 00 50 8b 44 24 04 89 44 24 bc 58
    SS:ESP: 007006f4 03720016 007006f4 007006f4 f000ff54 00000107 000000e7 00000107
    00000107 000005df 000000ff 00210202 0009d8ee
    Exiting with error: 800d0014
    Pinball Illusions and Virtual Pool crashes with similar messages.
  • Micro Machines plays ok but the computer hangs on exit.
  • World Class Leader Board crashes when loading title screen.
  • Several other games work fine: Duke Nukem 3D, F29 Retaliator, IndyCar Racing II, Lemmings, Loom, Prince of Persia 2, The Lion King, The Lost Files of Sherlock Holmes, WarCraft II, Zoop.
Reply 1925 of 1988, by MrSegfault
How would I get utilities like CPUSPD to work with VDPMI? It just gives me a SIGSEGV error when running it.
CPU: Intel Core 2 Duo E7500 2.93 GHz Dual-Core
Graphics: EVGA NVIDI​A GeForce ​7900 GT 25​6MB + Zalman VF9​00-Cu Cooler
Memory: 2 GB (1 x 2 GB) DDR2 Memory
Soundcard: Creative S​oundblaste​r Audigy 2​ ZS
Storage: 1TB + 500GB SSD + 120gb HDD
Reply 1926 of 1988, by RayeR
VDPMI as V86 monitor prevents DOS apps acessing some critical structures in memory (is more restrictive than others - EMM/JEMM/QEMM386 etc.). As I wrote before, my CPUID, MTRRLFBE, SMB, etc. are not the only apps that manipulates GDT/LDT to setup a callgate...
Reply 1927 of 1988, by MrSegfault
Found a temporary workaround to this issue. (Until a better solution exists)
Since you can manually run VDPMI, I made it so that I run the CPU slowdown tool before starting the VPDMI server.
Like this
CPUSPD ...
VPDMI
SBEMU /vmpu
Reply 1928 of 1988, by shawnmos
sergio_prado wrote on 2026-07-12, 02:10:
That sounds very promising! The link doesn't seem to work. Is there another place I can grab it from?
Reply 1930 of 1988, by LSS10999
Did a test on my main gaming rig (X570) where SBEMU might be of some relevance... it works well, but I noticed something off. I'm using the VDPMI version from GitHub.
While my X-Fi Titanium HD can be used by SBEMU using the CTXFI driver and it works as expected, there's a constant gray "ctxfiirq x" line being printed every a few seconds, with "x" starting from 2000 and increases by 2000 on every output. This output can mess up text mode interfaces while mostly harmless in graphical modes (in game). No such behavior observed with Intel HDA. Both X-Fi and HDA work with SBEMU on my system.
DIGPAK's SFX portion (SETD) doesn't seem to work correctly. It detects the presence of Sound Blaster, but hangs on testing. Music portion (SETM) works correctly for both FM and MIDI (using soundfont). In case of CTXFI, even after SETD hung on testing the sound driver, the "ctxfiirq x" lines continue to be printed.
Tested these games:
- Skyroads (works)
- Spear Resurrection (Wolf3D engine, works)
- Duke Nukem 3D (SETUP part works, SFX and Music tests pass, Reverse Stereo needs to be checked for correct channel output. Hangs with screeching noise a few seconds after launch, during opening cinematic)
- Jazz Jackrabbit (works correctly ingame, but I get a VDPMI Server Exception 0e, Error 0002 on exit).
- Titus the Fox (needs EGAFIX for my Ampere video card. Does not work, crashes and hangs the system with first a VDPMI VM86 Exception 0d Error 0000 followed by a VDPMI VM86 Exception 06 Error 0000)
- Bio Menace (works, needs EGAFIX for my Ampere video card, and additionally /LATCHPEL to fix scrolling issues)
- Rise of Triad (works without crashes, but the sound seems sluggish)
- Tetris Pro by Michiel Ouwehand (works, the music seems sluggish by default but will play normally when I move mouse cursor. The game is not intended to be played in V86 mode and will warn you if detected V86, but will still allow the game to run.)
- AstroFire and TerraFire (works in SETUP, but I get a constant, screeching noise ingame and sound does not actually work there. DOS4GW)
EDIT: Turned out there was already an issue about this. The author of the issue has since closed it suggesting rerouting debug log to serial, which I've no idea how to do with official releases, and my board doesn't really have any standard serial port exposed.
EDIT 2: Did additional tests using HDA instead of CTXFI (both works, but I'd hope the log spam with the letter can be fixed eventually). Real mode games (V86) work better in overall while Protected mode games are hit-or-miss.
Reply 1931 of 1988, by crazii
shawnmos wrote on 2026-07-02, 23:30:
Oops, I think it's the same underlying reason that JEMM and VPDMI doesn't work, the different outcomes is due to different implementations. but you may want to try the XHDD driver mentioned by others.
Toshiba Satellite Pro 4300 - YMF744, Savage IX
Toshiba Satellite 2805-S501 - YMF754, GeForce 2Go
IBM Thinkpad A21p - CS4624, Mobility Radeon 128
main: Intel NUC11PHKi7C Phantom Canyon: i7-1165G7 RTX2060 64G 2T760PSDD
Reply 1932 of 1988, by crazii
ntalaec wrote on 2026-07-15, 10:30:
Thanks for this project!. I've been using the latest experimental build with VDPMI. Works better than the one with HDPMI in my c […]
Thank you for the test and feedback!
Aladdin require 64K EMS page frame and you can try /EMSX instead of /EMS, which have 64K page frame. You're running VDPMI in command line so /EMSX is not fully tested on that scenario. or you can try to disable some option ROMs or USB legacy support in you BIOS to make enough upper memory.
I will try to figure out the other compatibility issues.
Reply 1933 of 1988, by crazii
LSS10999 wrote on 2026-07-18, 05:07:
Did a test on my main gaming rig (X570) where SBEMU might be of some relevance... it works well, but I noticed something off. I' […]
Tested these games:
- Skyroads (works)
Thank you!
There seems a lot more compatibility issues than expected. 🤣. I will remove the log spam for CTXFI on next release.
Reply 1934 of 1988, by ntalaec
crazii wrote on 2026-07-25, 04:24:
Thanks! Aladdin now works without issues. VDPMI causes a lot of problems for other software in my computer so I don't load it in CONFIG.SYS. I have found games which don't work unless VDPMI is loaded with DEVLOAD, which seems to work fine. Some games crash without EMSX parameter and others crash with it.
I have found other weird issues:
Warcraft 2: does not load (Sound Blaster not found) unless I ran other game before (like Aladdin).
Duke Nukem 3D: sounds in 16 bit are distorted, 8 bit sounds play fine. Music plays fine.
Descent 2: 16 bit sound not available. 8 bit sounds are distorted during gameplay. Music plays fine.
Reply 1935 of 1988, by RayeR
To mitigate the issuse with HDD and V86 mode I use this special version of XHDD (thx to Jack).
It must be loaded twice in config.sys like this:
[4]
DOS=HIGH,UMB
REM XHDD must be preloaded before switch to V86 mode
DEVICE=C:\DOS\PLUS\XHDD.SYS
DEVICE=C:\DOS\HIMEMSX.EXE /METHOD:FAST /NUMHANDLES=64
DEVICE=C:\DOS\JEMM386.EXE SPLIT FASTBOOT VERBOSE
DEVICEHIGH=C:\DOS\PLUS\XHDD.SYS /S64 /H
DEVICEHIGH=C:\DOS\PLUS\XDVD2.SYS /D:MSCD000 /H
STACKS=9,256
BUFFERS=15
LASTDRIVE=Z
FCBS=4,0
FILES=80
SHELL=C:\COMMAND.COM C:\ /E:1536 /P
Reply 1936 of 1988, by crazii
RayeR wrote on 2026-07-16, 01:28:
I'm adding a white list for those programs for special handling. Hopefully this problem can be solved.
the whitelist should be in a config file and anyone can add programs if needed.
Reply 1937 of 1988, by ntalaec
crazii wrote on 2026-08-23, 07:46:
Can any program be added to this list? Game Wizard 32 does not work with SBEMU with VDPMI and vice versa.
Reply 1938 of 1988, by vico
I tested the new version of SBEMU with VDPMI on my PC with a VT82C686 southbridge. I encountered some problems: the keyboard LEDs don't light up, the EMS memory doesn't seem to be working properly because some programs like DOSZip don't detect it, and I'm experiencing distortion and crashes with some games
Reply 1939 of 1988, by crazii
ntalaec wrote on 2026-08-24, 09:00:
EDIT: Sorry I mistake the two feedbacks.
the whitelist just enable writing to "system memory" of vdpmi to allow the drivers to hack GDT. I don't know if Game Wizard 32 is the case, but I will test it to find out a solution.
Another way is provide full ring0 privilege (ring0 descriptors for those clients) which will work. but it needs a lot of changes, and that will be considered later. CWSDPMI has a standalone build CWSDPMR0 to simplify the case.
UPDATE: tested game wizard 3.0a, it needs VCPI and I'm gonna add VCPI to the v86 monitor soon.
I think it could be better adding a VCPI whitelist so that some games' VCPI requests are blocked, because some games prefer VCPI to DPMI, even if both they supports. but VCPI is a ring0 protected mode interface providing a whole separated PM space, making original PM port trapping invalid.
