Reply 480 of 513, by Ozzuneoj
- l33t
Tzk wrote on 2026-07-15, 04:48:Sadly software tools can only read the SPD of the ram sticks. There's no way to identify the chips that way. However ram chips g […]
Ozzuneoj wrote on 2026-07-14, 18:29:This is going to sound like a total noob question, but I'm asking because my DDR test system is not currently ready to hook up... what is the best program to identify the chips used on memory that has glued-on heat spreaders? Is there anything better than CPU-Z for something as old as an Nforce 2 system?
I have lots of memory with head spreaders, and I really don't want to tear them apart to see what chips they use. I have 5 OCZ PC3200 "1024MB EL Dual Ch Platinum Edition 2-3-2-5", a Crucial Ballistix of some kind (looks like I wrote on it 512MB DDR400 2-2-2-6 2.8v ... not sure when I did this, 🤣) as well as various Corsair XMS, SuperTalent and Patriot memory.
EDIT: Were there any overclocking-friendly DDR chips that were in the smaller, more square-shaped (DDR2-like) BGA package? I have come across some of those as well, but they have minimal markings. On one "AMPO PC3200/1GB" module the chips are mostly blank except for a tiny little bullseye symbol and "DDR DXT".
Sadly software tools can only read the SPD of the ram sticks. There's no way to identify the chips that way. However ram chips got very specific metal dots or fins on the shorter edge of the plastic package. So if you can see the short edge below the heatspreaders, you can at least guess what they are. Winbond for example does have two lengthy metal tabs. Samsung 256mbit rev. F chips (TCCC/TCCD) got six tiny metal dots ( . .. .. . ). Micron has a round cutout. Other chips mostly have four dots, but their position varies.
There are BGA chips - for example there's Samsung TCCC (TSOP package) and ZCCC (BGA package). Or Infineon BT-6 (TSOP) and BC-6 (BGA). The only "good" BGA chips i know about is Infineon CF-5 (basically 512mbit CE-6 in BGA package). If you got those, try testing it. Just beware that some of these OEM sticks were made cheap and may have 128Mx4 organization, which will only work on Athlon 64 but not 462 or 423/478/479.
Besides that you can check old ram chip lists or the above mentioned ddr chip thread on hardwareluxx forums. Your Ballistix got their chips on the white label. If it's for example named: BL12864AL1065.16FD3, then it's 5B D chips. If it's named ....16TG then it's 5B G My DDR400 Ballistix (2x512mb 5B G) are able to run 2-2-2-5 2.8V at 200Mhz and 2.5-2-2-9 250Mhz 2.8V on Nforce 2. Setting Tras to 9 is key for stability at 250MHz on my system.
Regarding your mentioned sticks: There are two huge lists for Corsair XMS which you can check. One is the DDR Inquiry List on Corsair forums and the other was compiled by stunned_guy on Hardwareluxx. I took both lists and made them searcheable here . I also found a bit of information for GEIL and Twinmos (see last link). You can also check the DDR1 databases ( Link #1 for 512mb and #2 for 1gb) on hardwareluxx, those are mostly accurate but may contain smaller errors.
In the end it's trial, error and a lot of testing. Having a good 939 system at hand to pre-test the rams is a great idea.
Thanks for the info! I kept reading about the little metal dots and tabs but it never occurred to me that you could see these under the edge of the heatspreader. That helps tremendously! Looks like none of my OCZ Platinum is using Winbond. They all just have four dots, though some are closer together or further apart than others. If there are example pictures anywhere of all the dot patterns that would help me ID them a bit better. There are a few at the Hardwareluxx page linked earlier and I would say the OCZ ones most closely resemble either Hynix or Aeneon\Infineon\Qimonda, but without a more comprehensive list of chips and example pictures it's hard to say for sure.
Out of all of my DDR, I managed to find one single stick that definitely uses Winbond chips that are relabeled as "Liberty". It has a very generic green heat spreader with no labels or other information on it.
The metal tabs at the ends and the two dots on the top are unmistakable. Sadly, again, it is just a single one. If only I had a pair of them...
Regarding testing them on a 939 system, I have an Nforce 3 Ultra system with an X2 4200+ that I can use. What does the 939 system get me with regard to memory testing vs just using my Nforce 2? It's been so long since I messed with overclocking on 939... I can't remember what kind of flexibility I get with setting different memory speeds.
