First post, by Dleatherhoff
Hello,
First of all, this is my first post but I've been long time lurker here, so hello everybody.
I finally built my "nostalgia" retro setup:
"P2 450" slot 1 processor
"P6 BAT -A+" motherboard
"FSP group ATX 300 GTF" PSU
"Voodoo 3 3000 AGP" 3d accelerator
"sound blaster live! SB100" sound card
"Win 98SE" OS
"Maxtor 20GB IDE HDD and CF adapter" storage
On a samsung syncmaster 750s CRT
I have two questions:
- When I turn on the power strip after a period of inactivity, pressing the case power on switch does nothing, I have to wait 10 seconds and then press it for the system to boot normally.
If I shut down the system and power it back on shortly, it boots right away. It really looks like the PSU needs 10s to "charge up" and then it's good until I shut down power to it which causes it to progressively go back to "uncharged" state.
Could anyone shed some light on this behavior? Capacitor issues in the PSU?
-second and less pressing question: The brightness and contrast settings on my syncmaster 750s are cranked to max. The pixture is good but If I ever needed to up the brithness it would be impossible. Thing is, even restoring factory setting in the OSD puts thos values to max. Is it a normal setting for this particular CRT?
Thanks!
Reply 1 of 10, by Garrett W
Hi there, nice system.
Before you go opening up your PSU, can you take a photo of your motherboard and show us the capacitors close to the CPU? They might be going bad.
b) As far as the monitor goes, it seems like it has seen a lot of work. You can usually confirm that by going into the service menu, if one is available, and seeing the runtime/hours. Likely, this one has been used quite extensively and as such has deteriorated over the years. Not sure if there is a lot that can be done, you might be better off sourcing another one in the event that this one decides to hang the gloves.
Reply 2 of 10, by Dleatherhoff
Sure thing:
The attachment IMG_20260709_133943.jpg is no longer available
The attachment IMG_20260709_133930.jpg is no longer available
The attachment IMG_20260709_133922.jpg is no longer available
Let me know if you need other pics
As for the monitor, I'm trying to get to the service menu but so far couldn't find the service manual for a 750s
Reply 3 of 10, by Dleatherhoff
Edit: seems there is no service OSD on Samsung syncmasters and everything is done with Softjig.exe, a signal generator and an interface board that's way out of my reach
Reply 4 of 10, by Dleatherhoff
Edit2: Checked for bulging/leaky caps, apart from a bit of dust they all look flawless. If it's the power supply I won't have the technical skills to repair it so I'll have to use a new one
Reply 5 of 10, by NeoG_
I am using a thermaltake 430W PSU from round 2004 in my SS7 build, and it does the exact same thing. The power button is unresponsive for a few seconds after turning on the power supply. I'm not sure if it's the mainboard or the power supply but it never seemed to cause any other issues so I just live with it.
I suppose to test if it's the mainboard or PSU, you can check if the PSU turns on instantly by grounding the green power on wire and then switching on the main switch at the back. If it comes on instantly it means there's a delay with the mainboard being able to switch on the power supply.
98/DOS Rig: BabyAT AladdinV, K6-2+/550, V3 2000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, SB16-SCSI, PicoGUS, WP32 McCake, iNFRA CD, ZIP100
XP Rig: Lian Li PC-10 ATX, Gigabyte X38-DQ6, Core2Duo E6850, ATi HD5870, 2GB DDR2, 2TB HDD, X-Fi XtremeGamer
Reply 6 of 10, by Dleatherhoff
I have a tested enermax 300w on the way, I'll swap them and see if it fixes it... as you said apart from the 10s wait time the system works fine, but still I'd like to know if it's normal behaviour.
Reply 7 of 10, by TELVM
Dleatherhoff wrote on 2026-07-09, 09:32:
... When I turn on the power strip after a period of inactivity, pressing the case power on switch does nothing, I have to wait 10 seconds and then press it for the system to boot normally.
Could anyone shed some light on this behavior? Capacitor issues in the PSU? ...
Yep, PSU caps are bad and their ESR (resistance) is too high to start.
Once they're warmed up (like when powering back on right after shutting down), ESR decreases enough to allow starting.
A trick as old as the hills:
Blowing a hair dryer into the PSU
Your PSU needs to be recapped or replaced as soon as possible.
Let the air flow!
Reply 8 of 10, by Dleatherhoff
Thanks for the info, enermax here we come! From my research that's a good brand and the seller tested it before shipping.
Reply 9 of 10, by Dleatherhoff
Update: putting the enermax psu in solved the issue, also snagged a iiyama vision master pro 410 to replace the samsung.
Thanks for the help!
Reply 10 of 10, by Dleatherhoff
Well, spoke too soon. The issue is still there.
The system works perfectly apart from that weird delay between switching on the power strip and the computer's power button responding to being pressed.
Oh and the windows clock keeps falling behind, I put a new coin cell in the motherboard to see if it fixes it.
Should I send the mobo for preventive recapping?
