First post, by alexclaudiu2003
A masterpiece of retro computing hardware and software engineering. This system is the result of 6 years of daily work, research, and meticulous optimization. Meticulously cleaned, tested, and fully optimized over 6 years. Silent and COMPACT, perfectly optimized to sit elegantly on any modern desk without taking up space or making noise. Features a simple boot cd for Full Backup & Restore to original state (internal ntfs partition)
[ HARDWARE SPECIFICATIONS ]
• CPU: Intel Pentium 4 Prescott @ 3.0 GHz (800 MHz FSB, Socket 478, 1MB L2 cache)
• Motherboard/Chipset: Dell OptiPlex GX270 (Intel Springdale i865G chipset - legendary stability)
• RAM: 512MB DDR1 Dual Channel (400 MHz, 128-bit)
• Primary 3D Card: NVIDIA Quadro4 580 XGL (AGP 8x, based on the legendary GeForce4 Ti architecture - scored 7,602 points in 3DMark 2001)
• Retro 3D Glide Card: 3dfx Voodoo 2 12MB with premium heatsinks installed (scored 980 points in 3DMark 2001)
• Sound Card: Aureal Vortex 2 AU8830 with General MIDI Wavetable Daughterboard (pure, authentic A3D sound!)
• Storage: WDC Caviar SE 160 GB P-ATA Ultra-ATA 100 MB/s, 7200 RPM, 8MB cache
• Optical Drive: DVD-ROM
• Connectivity: Wireless USB Dongle (fully configured with Windows Me drivers)
• Legacy Ports: Floppy Drive, 8x USB 2.0 ports
• Power Supply: Ultra-silent 210W Dell PSU
• Dimensions (Vertical): 10.8cm x 43.1cm x 39.0cm | Weight: ~10 Kg
[ SOFTWARE & OPTIMIZATION ]
• OS: Windows Millennium Edition (Me) - meticulously configured with all official updates. It is rock-solid stable, goes into Standby, and resumes flawlessly without crashing.
• Why Windows Me instead of 98?
- Native USB mass storage and USB 2.0 Plug & Play support.
- No blue screens when removing USB sticks, CDs, or floppy disks during reading.
- Driver locations remain permanently saved.
- Native support for almost any USB Joystick without external drivers.
• Games: 170 classic PC games installed (Full Versions, 99% with working intros, configured manually to correct graphic/sound settings with official patches).
• Racing Games: All tracks and cars are fully unlocked without affecting single-player progression or starting a new campaign.
• Multiplayer Perks: The ONLY PC in the world pre-configured with Counter-Strike 1.0 (and last beta version featuring the scoped M4A1 and custom CT Mauser/USP pistol) WITH BOTS. Half-Life (v3248 from 2005) and CS 1.6 also have bots fully configured and can be played online using the included Wi-Fi adapter.
• Office & Design: Corel Draw 12 and Microsoft Office XP pre-installed.
• Legacy Compatibilty: IRQ 5 is strictly reserved for pure MS-DOS gaming compatibility.
[ BACKUP & RECOVERY SYSTEM ]
• Full Peace of Mind: A customized recovery system is pre-configured. Windows Me is on partition C:, and games are on D:.
• Invisible Partition: A hidden NTFS partition contains a full system copy.
• Backup: Package includes a Bootable Recovery CD. If you make a mistake or corrupt the OS or games, you can restore the entire system or games to its pristine in just a few minutes using the CD (just press F12 during boot to select the CD drive).
