First post, by cloverskull
Hey friends, I have a gotek as the only floppy device on my computer. I put multiple .img files onto a properly formatted USB drive. I can "see" these and choose them with the gotek itself. However, when I do, and I type "a:" in DOS, I get the abort/retry/fail message. Thing is, when there's a virtual floppy inserted, the abort/retry/fail screen takes a few seconds to come up. Any ideas what could be causing this?
The .img files were previously .ima files but from what I've read, simply renaming them should be fine.
Thanks!
Reply 1 of 1, by cloverskull
Disregard, I needed to put a jumper on JC and it works fine.
