First post, by robertmo3
Magic Carpet 2
level 5 (about 5 tiny volcanic islands)
at the beginning in official dosbox two armies fight in the crater (one army waits for the other)
while in daum and staging they fight on the bridge (both armies rush into each other)
Reply 2 of 5, by robertmo3
i just noticed both behaviours in one dosbox version - will be testing that
Reply 3 of 5, by robertmo3
when i have:
[autoexec]
path=1:\;2:\
battle is on the bridge
but when i have:
[autoexec]
path=1:\
battle is in the crater
Reply 4 of 5, by robertmo3
i was using DOSBox ECE r4481
Reply 5 of 5, by robertmo3
but the same happens in dosbox 0.74-3
if you don't have path you can also use loadfix -f for the bridge
