First post, by cloverskull
Has anyone seen anything like this before? When I have my case's reset button hooked up to the header on the motherboard, the computer will no longer POST. When I manually short the pins with a screwdriver, it resets as expected. How is the reset button breaking the POST even when it's not being depressed?
Reply 1 of 8, by Repo Man11
The only explanation that I can think of is that the switch is stuck closed. If you have a meter you can test to see if the circuit opens and closes when the switch is depressed.
Reply 2 of 8, by DaveDDS
Is this a switch you've used for such a thing before?
Some "buttons" are N.C. (Normally closed) - this means it makes a connection when you are NOT pressing the button, and opens the connection when pressed.
When you press (and hold) the button, does the system POST?
If yes, it's an N.C. button, if no the button(or it's wiring) is defective.
If you have access to a multimeter, you can test connectivity of the button when pressed and while NOT pressed.
https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChw can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small filetransfer(w/o netSW)via Lan/Lpt/Com
Reply 3 of 8, by cloverskull
Thanks to both of you. I've used the switch before but it doesn't click when depressed, it always felt "squishy" if that makes sense. Now on this motherboard it isn't working for me. I have no idea if the switch has gone bad in the interim but that seems the likely culprit...I won't know for sure until I find my multimeter and test it.
Assuming the switch itself is bad, what's the fix?
Reply 4 of 8, by NeoG_
cloverskull wrote on 2026-07-27, 22:59:
Replace the switch, unless it can be disassembled and you can unstick it
If the contacts are stuck together because of corrosion or oxidisation, maybe if you spray contact cleaner into it and mash the button a bunch it might restore it
98/DOS Rig: BabyAT AladdinV, K6-2+/550, V3 2000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, SB16-SCSI, PicoGUS, WP32 McCake, iNFRA CD, ZIP100
XP Rig: Lian Li PC-10 ATX, Gigabyte X38-DQ6, Core2Duo E6850, ATi HD5870, 2GB DDR2, 2TB HDD, X-Fi XtremeGamer
Reply 5 of 8, by Repo Man11
Some contact cleaner might do it.
Reply 6 of 8, by DaveDDS
"not clicking" is not uncommon for a push button - typically only the better ones "click", not normally needed/used in a RESET circuit.
Did you try holding it down - just to confirm that it's not N.C.?
Fix is easy - replace it. The only "tricky" parts can be if it's embedded in some sort of front-panel insert (where you have to figure out how to fit a different one), or you have no soldering skills.
(Then you find a friend that does, or take it to a repaid shop)
Reply 7 of 8, by Major Jackyl
You could check the insides. Sometimes taking it apart and putting it back together fixes it. But if you see damage in there, it's most likely on the button part, where the spring rides in a path, which is the "action" of the switch.
To open it, you gently fold the ears (using a pin or small screwdriver) and pull it apart , slowly.
The attachment 20260727_181135_1.jpg is no longer available
This next type of switch is a bit tougher to open AND reassemble. You push the grey part in/black part out while pulling, one side at a time. On both these switches, the spring has to sit on the bottom on the "c" shaped spring piece, which applies tension
The attachment 20260727_183156_1.jpg is no longer available
Replacing it is the easiest option and guarantees success.
Daily Units:
ASUS P55TVP4, P-MMX233, Matrox2064W, CT2770
ABIT IS7, P43.2(SL7E6), PNY6600GTS, Audigy(0090)
ASUS M2N-SLI, A64X2-5600+, EVGA 8600GTx2, Audigy2(0240)
ASUS ST-990FX, FX-8350, MSI GTX760x2, SB X-Fi(0460)
MSI Z690, i9-12900K, MSI RTX3090, SB AE-7
Reply 8 of 8, by cloverskull
Thanks for the help and especially for the photos, I appreciate it!
