First post, by DoZator
Has anyone managed to set up the sound in Dune II like this:
so that the music is played on the MT-32, the sounds and effects are played on the SC-55, and the voices are played on the SBPRO? If so, could you please share and explain more about it? What do I need to do? What port should the MT-32 be on, and what port should the SC-55 be on? What should be written in the line "SET BLASTER="?
I noticed that the installer does not offer to manually assign ports for each device individually, and the game uses the same port 330 for both the MT-32 and the SC-55, as well as port 388 if ADLIB is selected. Is it necessary to modify the game's executable or configuration files, or is there a different approach to achieve this result (if it is achievable)? Thank you!
