First post, by ratfink
I have Windows 11 on a min-PC, I use a Razer Naga mouse that is probably close to 10 years old now.
I noticed when playing games recently that I was having trouble dragging items in-game. Now I also do photography, and today I find that when I select a set of photos to drag to another folder (or flickr or whatever) I can seelct the items OK but when I click on them to drag them, instead they get deselected and the one the mouse is on is selected.
I've had this is the past, a long time ago. I never change any settings, in fact I only use this PC to plays games or edit/upload photos. So it looks like a Windows update issue to me.
Any advice on what to change to get things back to how I want them? I can't see any mouse settings that look promising...
I don't have a Razer driver loaded, that used to be annoying enough in Windows 7. All I am using is HID-compliant mouse, whatever Win11 loaded when I plugged the mouse in nearly a year ago (I've had this PC since last autumn).
Reply 1 of 4, by NeoG_
I had this issue on a mouse, and the mouse button was failing. It would quickly let go and click again while dragging items. If you have another mouse to test with it would rule that out.
98/DOS Rig: BabyAT AladdinV, K6-2+/550, V3 2000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, SB16-SCSI, PicoGUS, WP32 McCake, iNFRA CD, ZIP100
XP Rig: Lian Li PC-10 ATX, Gigabyte X38-DQ6, Core2Duo E6850, ATi HD5870, 2GB DDR2, 2TB HDD, X-Fi XtremeGamer
Reply 2 of 4, by robertmo3
check if the same happens if you swap primary and secondary buttons
Reply 3 of 4, by VileR
Not on Win11, but whenever I've had this, it was either a power or bandwidth issue on the specific USB controller. Usually fixed by plugging the mouse (or the receiver, if wireless) into a port on another controller. Windows updates can definitely screw with the relevant motherboard device drivers, because of course they do.
Reply 4 of 4, by ratfink
Thanks all, I'll try to check out some of these ideas tomorrow. Interesting about the bandwidth/power possibility, I probably had a camera plugged into the PC at the time, which I very seldom do, to read from the on-board storage. Maybe that was a factor.
