First post, by Nexxen
- l33t
Hello everybody!
I have this board, https://theretroweb.com/motherboards/s/ncr-pe … l-computer-pc-8
It has a 8MHz cpu
The board has issues with VGA ISA cards, one works the other doesn't. For now I have one and I'm leaving this for later.
My current issue is that I can't make it boot via FDD or HDD. HDD has only 1 to 47 values to be selected;
FDD reads but won't go past:
"rom basic (int 18h) is not supported
disk error, insert system disk
and press any key to try again
Before I kill myself trying the wrong things, I tried MS-DOS 6.22 on a 3.5" disk, it read but no loading.
Controller card is detected as it responds (goldstar 2 chip).
I still have to set the HDD but I need to create a correct size before trying.
Any in put is greatly appreciated. Pics will be loaded later.
Thanks!
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- Bare metal ist krieg.
