Reply 20 of 31, by TELVM
- Oldbie
shevalier wrote on 2026-08-08, 11:24:Near the RAM slots, there is an unpopulated footprint for an electrolytic capacitor. If it's on the +3.3V rail, I would try runn […]
If it's on the +3.3V rail, I would try running a jumper wire to it.
That way the run will be much shorter, and you can use a thinner wire.
Plus, it will look much cleaner.But again, I don't have this board.
I don't know where this pad goes.
This needs to be checked with a multimeter.
Shevalier if you mean this one:
^ It's a CPU VRM output spot that they just left unpopulated (like the one to its extreme left in this pic, that I've circled in blue). They both are in parallel with the six that came OEM populared.
Let the air flow!
