Which USB 2.0 cards for old motherboards
Reply 400 of 414, by DJNW
UK folks: scan’s got a combo usb2 & FireWire card, WITH an internal header AND comes with a 3.5” front panel for it!
What’s the price, I hear you clamour? Not even 50p!
https://www.scan.co.uk/products/scan-2x ... ternal-hub
Can’t vouch for anyone else’s compatibility , but it’s fine on my 440Bx board, 3dmark figures are nigh-identical and it happily hosted a usbode to install VB6. If it doesn’t work, at least it’s cheap!
Reply 401 of 414, by Kahenraz
Which chip is on it? If looks like the via USB controller in the photo but it's hard to tell.
Reply 402 of 414, by digger
From what I gathered from an AI conversation, there might actually be a good reason to skip USB 2.0 and go straight to USB 3.0 for older motherboards.
The reason for that is that the xHCI controller in USB 3.0 cards is more intelligent than the EHCI controller in USB 2.0 cards and effectively offloads the CPU and does a lot more of the processing independently from the CPU.
That is the case, regardless of the generation of the USB device that you plug into such a card (USB 1.0, USB 1.1, USB 2.0, USB 3.0). All such devices are handled by the xHCI controller. This is different from USB 2.0, where the card would have an EHCI controller just for USB 2.0 devices, plus a OHCI or UHCI controller for USB 1.x devices.
There are USB 3.0 cards for conventional PCI slots, although those are always built around a PCIe-to-PCI bridge chip, since no USB 3.0 (xHCI) controllers were ever designed with integrated conventional PCI interfaces.
Because of the improved way how xHCI works, it shouldn't degrade the performance of older host systems, at least not as much as USB 2.0 (EHCI) cards do, even if you'll never be able to utilize the maximum bandwidth of USB 3.0, due to the limitations of the conventional PCI bus.
Of course this is theoretical. I have purchased such a conventional PCI card with a USB 3.0 (xHCI) controller and intend to test it on an older system soon.
Reply 403 of 414, by Kahenraz
I don't think that any of these 3.0 cards would have Windows 9x drivers?
Reply 404 of 414, by digger
Kahenraz wrote on 2026-08-10, 15:07:
True. This would be a solution only when running something like Linux or NetBSD.
Unless somebody takes a stab at writing an xHCI driver for Windows 9x. I mean, @onethirdxcubed wrote an HDA driver for Windows 9x with help from an LLM, so this might not be all that crazier. 🙂
Reply 405 of 414, by jmarsh
I can't really see why xHCI would behave any better than EHCI; at the register level there's not really that much difference between them. They both use the same memory structures (accessed via bus mastering) and the same hardware interrupts.
EHCI can support low/full speed devices without an OHCI/UHCI companion, if they have a built-in transaction translator - this was made mandatory for xHCI, simplifying both host controllers and hubs (EHCI hubs have to include transaction translators since the hosts may not...)
Reply 406 of 414, by onethirdxcubed
I don't think I'll get around to making a xHCI driver for Windows 98 any time soon; first I'm trying to figure out the "Crazy Mouse" problem when using legacy USB mouse emulation on the newest motherboard I can get Win98 Quick Install to work on. That system is a Lenovo Ideacentre with an i3 7100.
Being able to avoid using the UHCI controller would be nice to save resources though, since UHCI uses up one IRQ for every pair of USB ports and this can't always be shared with other devices when in legacy PIC mode.
An APIC and more modern ACPI driver for 9x would also be nice but is probably impossible because of the DOS underpinnings.
Reply 407 of 414, by myne
onethirdxcubed wrote on 2026-08-12, 00:55:
I think people get confused by 9x's relationship with dos.
Dos is absolutely used as a boot loader. Think Grub.
Dos is absolutely supported in a VM. Think dosbox.
Dos drivers/interfaces are supported. Think extended BIOS function calls/interfaces.
9x is not running on top of dos despite the appearances. It is its own kernel with its own control over everything.
The big problem with modern ACPI is a lack of people with the ancient wisdom of writing VXDs
I built:
Reply 408 of 414, by onethirdxcubed
myne wrote on 2026-08-12, 01:03:
I think people get confused by 9x's relationship with dos. Dos is absolutely used as a boot loader. Think Grub. Dos is absolutel […]
DOS is absolutely always around in Win9x, it's the first thing that is loaded into the System VM and any system calls that the upper layers don't handle will eventually make their way down to good old 16 bit DOS. (File system calls sometimes make it all the way down and then back up for compatibility reasons.) Various parts of the VxD layer and Windows kernel manipulate the internal DOS data structures in the system VM, again for compatibility. Even Windows ME doesn't fully get rid of the DOS layer though it does block the ability to boot into bare DOS or load 16-bit drivers all the infrastructure is still there.
Because of this, there are always going to be real limits on 9x compatibility that are inherited from DOS. The relevant limitation here is that IRQs have to be reflected into real mode for the system VM and there's no existing way to remap a larger number of IRQs to the legacy 15. To support the APIC you would have to rewrite VPICD, the PCI bus, Plug & Play, and find every assumption in every existing VxD driver based on never having more than 15 IRQs as well as every place anything acknowledges an IRQ by writing to the PIC. There is no such thing as a Hardware Abstraction layer here so writes directly to hardware registers are scattered all over the place. Some even get trapped and modified by other layers of the system.
Maybe someone with a lot of dedication and a Claude Code Max subscription could get it working but I have better things to do.
(Here's a relevant article from Microsoft.)
In comparison, a xHCI controller driver could be written only to the WDM layer and wouldn't have to touch the entire rest of the OS.
Reply 409 of 414, by myne
I was responding to the ACPI part.
Power management shouldn't be impossible.
I suppose it's neither of our faults the two acronyms are so similar.
I built:
Reply 410 of 414, by Duffman
Someone made one
https://github.com/yeokm1/xhci98
It runs USB 3.0 at USB 2.0 speeds but it's better than nothing at all.
MB: ASRock B550 Steel Legend
CPU: Ryzen 9 5950X
RAM: Corsair 64GB Kit (4x16GB) DDR4 Veng LPX C18 4000MHz
SSDs: 2x Crucial MX500 1TB SATA + 1x Samsung 980 (non-pro) 1TB NVMe SSD
OSs: Win 11 Pro (NVMe) + WinXP Pro SP3 (SATA)
GPU: RTX2070 (11) GT730 (XP)
Reply 411 of 414, by Choas75
GeorgeMan wrote on 2014-04-27, 10:10:
swaaye wrote:
What cards have you guys used that work reliably on old boards? I have a card with a VIA controller and it isn't even detected by 440BX or AMD 750. It does work on newer chipsets like KT266 though.
You need a card with NEC chip, not VIA. Some old computers refused to boot with the card installed and some others didn't recognise the card at all. 😊
I bought 3 different VIA based pci cards from ebay before finding out...
Same here on 440BX. With a VIA based USB 2.0 card it doesn't even POST.
NEC works fine.
Reply 412 of 414, by stanwebber
Duffman wrote on 2026-09-15, 09:15:
Someone made one
this is very cool. i have this driver running on an athlon kt133a win98se system with a startech usb 3.0 pci card (renesas on pci-e bridge) using nusb3.6e.
Reply 413 of 414, by yeokm1
stanwebber wrote on 2026-09-19, 11:09:
Someone made one
Thanks for using my project! I just made a release with full USB 3.0 support working on Win98!
Caveats though, this driver is still very early and USB 3.x standards/devices span a huge range so appreciate any issue/bug reports to help me improve it.
https://github.com/yeokm1/xhci98/releases/
Reply 414 of 414, by Sphere478
yeokm1 wrote on 2026-10-05, 06:58:
Thanks for using my project! I just made a release with full USB 3.0 support working on Win98! […]
Someone made one
😮 holy crap! Sweet!
Sphere's PCB projects.
