Reply 320 of 337, by bitzu101
- Member
douglar wrote on 2026-06-16, 12:14:That's a great card! {If you are lucky enough to find one or have a few hundred dollars to burn} […]
appiah4 wrote on 2026-06-16, 09:41:Mike_ wrote on 2026-06-13, 17:28:What would be a decent GPU for an Athlon XP build, that still has decent DOS support?
GeForce FX 5900
But it might be overkill unless you really need direct X 9.
If you are on a budget and can get by with Direct X7, an MX 4000 might be a good budget alternative. It's not the greatest 3d card, but decent for direct X 7 games and the DOS compatibility is high and the affordability is best.
Back in the day, I ran my Athlon XP 2100 with a Gefroce 4200ti and mainly played Direct X 8 games. That is also a decent card.
When I started playing direct X 9 games like Crysis and Halflife 2, I upgraded to an Athlon 64 and a Radeon 9800 because DOS compatibility wasn't so important to me at that time.
the geforce 4 MX 440 is also a decent card for dos gaming and ealry win 9x... i would not go for a mx4000 as they are poor.
