VGM Player for DOS
VGM Player for DOS
Player of .VGM files (Video Game Music) for PC under DOS.
1. CHIPS EMULATED BY SOFTWARE
These ones are calculated sample by sample, in real time, in the
CPU itself. You dont need nothing weird of hardware, only a card
that can put out PCM (a Sound Blaster or compatible, or the
parallel port with a Covox):
- PSG (SN76489) -- Master System, Game Gear, BBC Micro,
and a lot of 8 bit computers. With
support for "dual chip" (two PSG at
same time, thing of some arcade
boards).
- AY-3-8910/8912 -- MSX, ZX Spectrum 128, Amstrad CPC,
Atari ST.
- SCC (Konami) -- MSX cartridges with the Konami
SCC/SCC+ sound expansion.
- NES APU -- NES/Famicom (2 pulse, triangle,
noise and DPCM).
- FDS -- Famicom Disk System expansion, one
extra wave channel with phase
modulation.
- Game Boy / GBC APU -- 2 pulse (one with sweep), one wave
channel of 32 samples and noise.
- WonderSwan -- APU of WonderSwan / WonderSwan Color.
- PC Engine / TurboGrafx-16 -- 6 wave channels, noise, and
frequency modulation between pairs
of channels.
- YM2203 (OPN) -- PC-88, PC-98 and other japanese
computers (the PSG part of the chip;
the FM part goes through real
OPL2/OPL3, see section 2).
2. CHIPS THAT NEED REAL OPL HARDWARE
These ones are not emulated no more, they get translated: the
program grabs their registers from the VGM and resend them as is,
like OPL2/OPL3 commands, straight to the Yamaha chip of your card.
- YM3812 (OPL2) -- AdLib, Sound Blaster (Pro/16/AWE).
- YM3526 (OPL) -- the ancestor of OPL2.
- Y8950 (MSX-AUDIO) -- FM expansion for MSX.
- YMF262 (OPL3) -- Sound Blaster Pro 2/16/AWE, with its
secondary bank of 4 operators.
- YM2413 (OPLL) -- this one we dont really emulate it,
we approximate it reprogramming a
normal OPL2/OPL3 so it sound similar.
The real OPLL as itself is not
supported.
- FM part of YM2203 -- same trick like the YM2413.
3. AUDIO OUTPUT
a) Sound Blaster (by default, or if you put OUTPUT=SB). The
program find out what card you have reading the environment
variable BLASTER, that must be in your AUTOEXEC.BAT, like
this:
SET BLASTER=A220 I5 D1 H5 P330 T6
Plays through hardware DMA.
b) Parallel port, with a Covox or Disney Sound Source
(OUTPUT=LPT1, LPT2, LPT3 or LPT4). Here the PCM is already
mixed by the program in software and gets sent to a
homemade DAC plugged in the parallel port. Only sounds what
is synthesized by software.
5. CONFIGURATION FILE (vgmdos.ini)
PATH=<path> Where it looks for your VGM when it starts.
QUALITY=<n> Sample rate. Accepts 8, 11, 16, 22 or 44 as
shortcut (thousands of Hz), or any number
between 4000 and 44100 if you wanna fine
tune more.
286=1 The "SLOW286" mode. Several emulators (NES,
GB, WonderSwan, SCC, FDS...) lower a bit
their internal time resolution -- things
like Zero-Order Hold in the noise or
subsampling in the FDS -- for not drowning
the CPU in slow machines. You lose some
fidelity, but normally its not too much
noticeable. If you got something more
powerful (386/486 and up), put 286=0 or just
remove the line, better fidelity.
OUTPUT=<mode> SB for Sound Blaster (its what it does
anyway if you dont put this line), or
LPT1/LPT2/LPT3/LPT4 if you output through
parallel port with a Covox.
PGUS_TNDY=1 If you have a Tandy board (Picogus!) it
sends the PSG straight to the real chip
(port 0xC0 by default) instead of emulating
it by software. If yours is in other port,
PGUS_TNDY=<port in hex>.
NOSHORT=1 Shows the full name of the song (the one
that comes in the GD3 tag of the VGM) in
the browser, instead of the short name of
the file.
6. FILES.LST (song names without reading every .vgm)
From the browser, key S makes a FILES.LST in the current folder:
one line per .vgm, format "name.vgm=Song Title", taken from the
GD3 tag of each file. Once it exist, the program reads the title
from there instead of opening every single .vgm -- faster when
you enter a folder with lots of files, specially with NOSHORT=1.
If you delete or move some .vgm, just press S again to remake it.
TheElf 2026
Made in free time, for pure love of my 286
