Reply 120 of 128, by st31276a
appiah4 wrote on 2026-08-11, 19:57:I am genuinely not sure what you think I meant as well as what you want me to explain, but I will bite.
I put it like that because your words read as if the situation I perceive as a major problem with every-year-less-gnu/linux seems to be of little significance to you. If I read you correctly, I must be missing something and therefore would appreciate your perspective, so thank you for responding.
From my perspective, the problem field is not static. I watched this systemd cancer grow for more than a decade and every next year the situation is worse, not better. I know I can gentoo it, but before I stoop there I would rather give openbsd a try and see for myself what I have been missing out on all these years.
Even slackware 15 is not totally systemd-free any more…
I use i3 wm straight from xinit - don’t care what gnome and kde do with regards to systemd. I am simply mulling on a strategy to be systemd free in a sustainable way that does not have a near-future expiry date. Again.
At present I can still cobble up a “functional” box - my major concern is that the direction we are going in, is from bad to worse. This is not sustainable. I do not want to reserve mental bandwidth for nonsense like this all the time.
The water is getting too hot to be comfortable and I am not a frog.
That’s my position at least.
