WindowsME splash screeen
Reply 20 of 33, by ElectroSoldier
frank2243 wrote on 2026-08-10, 19:10:
ElectroSoldier wrote on 2026-08-10, 07:33:
The codebase used isnt in dispute. The fact is if I installed it with US it was there if I installed with UK it wasnt. […]
zapbuzz wrote on 2026-08-10, 07:14:
It is same codebase across English Locales including US, Australia, United Kingdom, Canada etc.
Non English Locales have a slightly different code base and have their own problems.
It really is the simple.
The splash screen was also not appearing in the french canadian locale on my side.
Yeah I dont understand how it works.
I dont know what triggers it to install and activate in the build.
Maybe Microsoft designed it so it only appears on the American version of the OS.
I havent played with that system for a while now, I would have to copy the files to another system to play with it over again.
Reply 21 of 33, by zapbuzz
On my pentium 4 machine I see the splash but only a blink of an eye and I’m in windows.
Like all 9x windows versions I recommend retail edition where possible this avoids the OEM SKU's unless the install media came with it's OEM PC originally.
All windows 9x Retail Discs actually had much less junk on them too.
The discouragement of using retail editions is lack of bootable CDROM support requiring floppy disk which can be resolved by copying optical boot from Windows OEM edition placing it into a Windows Retail ISO and burning a CDR (A DVDR can be used also.)
I have put a Windows Millennium Retail Edition Bootable ISO on archive.org for mostly me but also anyone however I won't link it here interested persons must search.
Reply 22 of 33, by ElectroSoldier
zapbuzz wrote on 2026-08-11, 08:44:
On my pentium 4 machine I see the splash but only a blink of an eye and I’m in windows. Like all 9x windows versions I recommend […]
I have a genuine WinME CD marked only for distribution with new PCs... Thats bootable media and is OEM.
I have a genuine Microsoft Select media thats bootable.
I have a retail CD thats bootable too...
Im a bit of a collector you see so I have all of them...
I tried all versions of the media believe me. I can not get the logo to appear when UK is set as the locale...
Maybe it is there its booting so quickly I dont see it because it doesnt have a chance to display... But its not on the PC as a file, or not one I can find.
From memory, as it was shelved as a project a while ago, it was on a 1.2GHz PIII. So not that fast.
Reply 23 of 33, by frank2243
Could it be possible that on my 800 Mhz thinclient I don't see it because the CPU is too fast?
Reply 24 of 33, by zapbuzz
frank2243 wrote on 2026-08-12, 13:39:
Its possible i have seen the splash on much older CPU systems.
Reply 25 of 33, by Yoghoo
My assumption is that this problem caused by the video card (in combination with bios/motherboard). I had the same problem in the past. Using the same OEM Windows ME CD on the same pc it showed the splash screen with one video card but didn't show it anymore when using another video card (after a clean install). Had this issue also on another pc.
Reply 26 of 33, by zapbuzz
zapbuzz wrote on 2026-08-12, 16:09:
Many people say its the GPU that causes it but its not really a bug its the fact the damn thing boots too fast to do the splash routine in time.
Reply 27 of 33, by Yoghoo
zapbuzz wrote on 2026-08-12, 16:32:
Well like I said that is not the case for me. Same PC, same CPU etc. With one video card no problems. With another one no splash screen. And I had this issue on multiple PCs.
Reply 28 of 33, by zapbuzz
Yoghoo wrote on 2026-08-12, 16:39:
So we need a list those that do and those that don't then.
Reply 29 of 33, by Yoghoo
zapbuzz wrote on 2026-08-12, 16:46:
Don't know if a list is helpful as I think it's not only the video card but also the combination with the motherboard/bios like I said before. But I can give an example of one of my PCs:
MSI K7T Turbo2 motherboard with an AMD Athlon 2400+ CPU:
Not working: ASUS GeForce FX5700 256MB (AGP)
Working: Aopen Geforce 4 Ti4200 8x V64(N8) (AGP)
Reply 30 of 33, by zapbuzz
Yoghoo wrote on 2026-08-12, 16:56:
Don't know if a list is helpful as I think it's not only the video card but also the combination with the motherboard/bios like […]
I appreciate your examples the GPU's you mention are within the generation supported by Windows Me drivers.
I notice your GPU's you comment are Nvidia I have an Nvidia on a pentium 4 motherboard but doesn't show it.
I remember the same Nvidia card of mine did show the Windows Me splash when running at 4X AGP on a pentium 3 motherboard, however only very briefly.
Reply 31 of 33, by frank2243
I have a Wyse Vx0 thinclient with a via eden 800 MHz processor.
Not working : the integrated VIA S3 UniChrome Pro (CN700)
Most recent drivers for Windows Me are installed.
Reply 32 of 33, by Shponglefan
I have a Pentium 4 651 3.4GHZ (Cedar Mill) system (see signature). GPU is a GeForce 4200 Ti.
Windows ME doesn't display the splash screen on startup. It just displays a blinking cursor.
I've even tried disabling L1/L2 cache in the bios to throttle the system. It still won't display the splash screen, though the boot up time takes considerably longer with cache disabled.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 33 of 33, by frank2243
F2bnp wrote on 2011-09-10, 13:05:
Hey guys, I've got another problem that I totally forgo to mention. It's very minor, but I kinda like the ME splash/boot screen. When the computer boots though, it only shows up for about a second and then it shows the AWARD BIOS hardware list again and a blinking curson on the bottom until Windows boots.
I'm not sure how to deal with this, I've tried a lot of things and it does the same thing even if I replace the default boot screen. I've heard about a Tweak UI option, but apparently it was removed after a certain version and I've got the latest one.
maybe our computers are just too fast to show it.
