Reply 40 of 43, by zyzzle
Falcosoft wrote on Today, 06:21:At least on the T430 an external monitor (even through a digital connection) behaves completely differently to the internal LCD. Unlike in case of NVIDIA cards video modes are NOT projected to the native panel size of the external monitor. This is obvious right from the beginning since e.g.normal text modes are projected to 640x480 fixed resolution that makes text modes especially ugly on Intel HD graphics through a digital connection.
Currently ASPECT's logic relies on the inner LCD behavior.
Yes, this I suspected, and of course it did not correct on the Sandy Bridge desktop. (This is connected via HDMI cable to external display). It is irrelevant like you said since the logic of that external monitor "corrects" 720x400 or 320x200 or 320x240 to 640x480. The external monitor does its own upscaling, which is poor, but does respect 4:3 ratio on 16:9 display. by windowboxing 4:3 content.
It is therefore understood that ASPECT.COM is intended only for internal laptop displays.
