Reply 20 of 34, by Karmeck
Re: Tyrian: Roland SC55 vs Yamaha MU80
listening to sc-55 here, the sound from the emulator is very different.
thinking here of the tyrian asteroid soundtrack.
Reply 21 of 34, by kode54
Did you reset the emulator first? Did you try both gm and gs reset modes? Also, are you using my midi_processing library to convert the loudness tracks to midi? (My library uses a novel conversion based on adplug and also does one thing the game only does for fm: portamento)
Reply 22 of 34, by Karmeck
kode54 wrote on 2024-04-05, 00:55:
I did, both resets as well. But, I tried the same midi with all my soundfonts. And the same difference is there. Even tried the demo in dosbox, same differens, compared to the recording.
Will do a recording. After this weekend.
But I think I lack some skill to identify the issue.
Reply 23 of 34, by EmperorGrieferus
Karmeck wrote on 2024-04-05, 18:52:
I did, both resets as well. But, I tried the same midi with all my soundfonts. And the same difference is there. Even tried the […]
Perhaps there's some SysEx bug in NukedSC that makes Asteroid dance sound weird because I had the same issue.
UPD: It was a version with messed up instruments.
Reply 24 of 34, by EmperorGrieferus
Dude, you downloaded the wrong version of the Asteroid Dance!
Reply 25 of 34, by kode54
Downloaded where? I can share the original .lds files, and my midi processing library and associated players can play them with their embedded GM mappings. Though you will need to send a reset to the midi device when done, since it leaves all channels with a full octave as the range for the pitch wheel instead of the default two semitones.
Reply 26 of 34, by Karmeck
EmperorGrieferus wrote on 2024-04-07, 00:15:
I did a GS reset (q, hold u, q, release u, w)
https://www.youtube.com/watch?v=iKZUyvwGkmQ
attached a recoding as there is clear differences in the beginning.
Reply 29 of 34, by EmperorGrieferus
I tried to test EmuSC but it failed to load control ROM. Control ROM version is 1.21. Maybe I should use another version?
Reply 30 of 34, by Karmeck
EmperorGrieferus wrote on 2024-04-07, 23:28:
1.21 works for me. I had emusc crash on me, had to rename one of the rom files so I could change some settings. Like audio to win32.
Reply 31 of 34, by EmperorGrieferus
Karmeck wrote on 2024-04-08, 11:57:
Already fixed the issue. Though, EmuSC's not worth it right now.
Reply 34 of 34, by gerwin
Veda wrote on 2026-08-15, 14:59:
Is anyone still following this? A new release just dropped, with huge amount of updates:
https://github.com/skjelten/emusc/releases#release-v0.7.0
To me it sounds almost like the real thing (maybe 95% correct)...
It seems promising, but my Linux x64 build crashes quite quickly when receiving midi data. Works only for a few seconds, then says "segmentation fault".
