ZuluIDE: A proper IDE device emulator for retro PCs
Reply 260 of 268, by aperezbios
trumpetlicks wrote on 2026-02-26, 01:59:
Oh, when I was shown the solder bridge, I fixed it in the next 5 minutes. Sometimes I struggle because I have the iron, the hot air, etc... but I don't have good magnification yet. Im just getting back into soldering, etc...
When in doubt, take it outside and take high-resolution, in-focus photos of the joints in question, with the best light (but not glare) possible.
Even without "proper" magnification, you can usually use this technique to identify solder bridges at this scale/complexity.
Reply 261 of 268, by crusher
Can ZuluIDE act as a DVD-drive replacement in a Windows 98 build?
If so, can it handle dual layer 8.5GB images?
Reply 262 of 268, by mbalmer
It absolutely can, so long as the disc images remain in one of the formats that the ZuluIDE can read (ISO or BIN/CUE). It doesn't identify as a specific type of drive to the system other than an "optical drive" — so in Windows 98, it shouldn't have any problem reading disc images that large.
Reply 263 of 268, by crusher
mbalmer wrote on 2026-04-16, 00:32:
That's good news!
Thank you for the information.
Reply 264 of 268, by RetroLizard
Another question I have: Can this read from .iso files made from DVD discs, like UT2004 DVD, Windows 7, etc?
(Yes, I'm already aware it might have problems with DRM protections. That's outside the scope of the question.)
Edit: This question was already answered.
Reply 265 of 268, by zorprime
I Got one Zulu Control Board 5.25 but never got it to work. Do I need more then just one wire. On my ZuluIDE?
Reply 266 of 268, by aperezbios
zorprime wrote on 2026-08-18, 07:22:
My educated guess for why you never got it to work is that you are running downrev firmware. Please contact us via e-mail, and we'd be happy to help you sort this out, one way or another.
Reply 267 of 268, by zorprime
aperezbios wrote on 2026-08-19, 00:01:
I have zuluide RP2040, audio dac kit and zulu control board. When I power the pc looks like the control board get no power at all. ? Is a simple firmware update will solve this use?
Reply 268 of 268, by aperezbios
zorprime wrote on Today, 04:21:
Without knowing which version of the firmware is currently on your ZuluIDE RP2040, it's not possible to answer this question accurately. You can always download the latest ZuluIDE firmware release from https://github.com/ZuluIDE/ZuluIDE-firmware/releases/latest
As requested, please contact us via e-mail and we will assist you in troubleshooting and resolving this issue. This thread is not intended for product support with individual customers.
