First post, by agovtman
I have created a fork of Nuked-OPL3 that performs much better (1.4x-2.2x faster) with the exact same output accuracy.
Nuked-OPL3-fast
I noticed a while back that Nuked-OPL3 does a lot of extra work it doesn't need to do inside the hot loop, like using function dispatches to compute stuff that could be computed inline or just precomputed into a LUT, etc. Moreover, Nuked-OPL3 is often the single heaviest user of CPU time in emulators that use it, so it was a productive target for optimization. I got to messing around, found even more optimizations I could make, and ended up with a version of Nuked-OPL3 that produces exactly identical output to the original, but is as much as 2.2x faster!
I have offered to NukeYKT to merge these changes upstream, but they do some "clever" things (in the pejorative sense: opaque, tricky, weird) that he might not want to drag into his codebase, so for now it exists as an independent fork.
This is a drop-in replacement for Nuked v1.8, and has already been adopted by dosbox-staging, libADLMIDI, and 86box. dosbox-x looks to be ready to merge it imminently, too.
If your project uses Nuked-OPL3, try switching to my -fast fork and run some performance profiling and see the difference for yourself!
PS: I have gotten Nuked-OPL3-fast running in realtime on an overclocked RPi Pico 2!
Reply 1 of 4, by M-HT
You can use _BitScanForward for the envelope timer on MSVC like this:
#if defined(__GNUC__) || defined(__clang__)
shift = (uint8_t)__builtin_ctz(eg_timer_low);
#elif defined(_MSC_VER)
unsigned long index;
_BitScanForward(&index, eg_timer_low);
shift = (uint8_t)index;
#else
while (((eg_timer_low >> shift) & 1) == 0)
shift++;
#endif
Reply 2 of 4, by tcaud
agovtman wrote on 2026-06-02, 04:04:
I have created a fork of Nuked-OPL3 that performs much better (1.4x-2.2x faster) with the exact same output accuracy. […]
Nuked-OPL3-fast
The meme took root a decade ago that inline code should be avoided because compilers would get imminently better and would handle inlining/vector ops/other common optimizations better and faster than people. And they did in cases habitually encountered in IT and engineering... not so much elsewhere. Thanks for making the fork.
Reply 3 of 4, by agovtman
M-HT wrote on 2026-06-11, 21:47:
Fascinating. I had no idea. Will look into more of these MSVC secrets. Thanks.
tcaud wrote on 2026-06-12, 07:27:
Well, to be fair, some compilers do gainsay some of my force-inlines because they Know Better™, and IIRC most of the performance improvement came from places other than force-inlining stuff, but... Yeah, people took "compilers are so good these days you don't need to" etc. a little too far.
Reply 4 of 4, by leileilol
Yeah i've never believed that gcc vectorizing / mtune worship. I still had to do manual unrolls when making PCem's voodoo filter with a big LUT to get it faster. Engoo had nested macro duff devices to draw a colored lightmap surfacecache faster, and that outpaces qrustyquake on the same CPU (Qrustyquake cleaned up a lot of code, unified a bunch of loops and has similar features to Engoo, so it's the only modern software port I can compare to - and gcc ain't helping it much)
