First post, by Solus
I have trying to mod Black Mirror (2003) to make it display Eng Subs with Czech Dub, know there is some successes more or less to speak hence the tittle. In order to do it first install Black Mirror English Version, next replace files grp3-grp6 from Czech Version in English Version of the game, and it will work, but the catch is the main character is silent and doesn't a single word at all, even the line characterset in cfg doesn't do anything, maybe in data.abd is something block Samuel Lines from playing them properly, so thus is need here, if anyone can lend a hand here, it'd be wonderfull. Thanks in advance for the replies.
Reply 4 of 9, by Solus
Feedback + testing is need here guys, I would like to know if there is missing audio from main character, mismatch of characters audio with text in order to better synchronize Chezh dub with Eng subs, I know some of missing audio after the intro, some minor mismatch, so thus reports are welcome here, thank you for your time.
Reply 7 of 9, by Solus
If you are Czech and game developer at same, and want to help me improve translation then please contact me at maximo.coller@gmail.com.
Reply 8 of 9, by Solus
To use Current Hybrid Build, I just use English install of the game.
Basically the structure is like this:
Cfg, DLL, adb, Exe are original english files. Modifying data.adb just causes black screen.
Gfx1-Gfx2.grp are original english files, one contains texture files and the other jusy music files, no change needs to be.
Gfx3.grp - modify, contains cinematics, but sounds are placed as wav in the game directory, due to structure you can't place then inside the game files directly. So thus ChatGPT help with wav files which is placed in English Install, will trick the game play those files, like Prologue, Confession and Ending cinematics, the only I change was cinematics chapters to display English subs, also Ending cinematics have their own build credits, but in orginal English Version they just play in the main menu credits.
Gfx4-Gfx6.grp - modify, these files contains voice records of NPC, Samuel lines, so therefore modify the most.
Another files like chr., patch files are original english files, since they don't do much aside from patch file which if place original czech file in English install breaks main menu a bit.
As for old Hybrid Version it contains some correct reading lines like Chronicles Book in Library in Black Mirror Manor, William Diary (With small parts Of Samuel eng audio here and there) Marcus Gordon Diary, Samuel dialogue lines which most of time works, most of time don't.
Current one mostly have correct placement of dialogue for NPC, aside from Ralph is still has eng audio, Samuel lines most of time use correct lines aside from reading Chronicles, William diary, Marcus Diary (they are still eng audio plays in there), remains of eng audio from Samuel here and there.
Reply 9 of 9, by Solus
You can use Nibiru script (https://oezmen.eu/gameresources/) to extract files of data.adb and gfx1.grp-gfx6.grp.
