Battle of the platforms: socket 939!
Reply 360 of 370, by nd22
NEW AMD performance rating for single core Athlon 64 based on the tests done in the 2 topics: battle of the platforms socket 754 and battle of the platforms socket 939.
Athlon 64 2800 socket 754 represents the baseline and all other models ratings are based on it.
AMD rating – NEW PR rating
1. Athlon 64 4000 socket 939 – Athlon 64 3800 socket 939
2. Athlon 64 3700 socket 754 – Athlon 64 3600 = Athlon 68 3800 socket 939/Athlon 64 3700 – Athlon 64 3600
3. Athlon 64 3400 socket 754 = Athlon 64 3500 socket 939 – Athlon 64 3400
4. Athlon 64 3200 socket 754 = Athlon 64 3200 socket 939
5. Athlon 64 3000 socket 754 = Athlon 64 3000 socket 939
6. Athlon 64 2800 socket 754
Reply 361 of 370, by nd22
Chapter 2: an investigation into dual core processors and PCI-express platforms for socket 939.
Part 1: while in the first chapter I used both AGP and PCI-express chipsets for socket 939, for dual cores only PCI-express chipsets will be featured.
But you can have a dual core in Abit AV8 with an AGP card for example!
Yes, you can, however the performance will be exactly the same as with a single core with the same frequency and L2 cache. You can not play the vast majority games released after 2004 at max settings with an AGP card so it makes no sense to test an Athlon 64 X2 with an radeon X1950 pro for example.
I found no game from 2004 and earlier that can take advantage of a dual core; most games from 2005 are single threaded only - there are some rare exceptions. And no, radeon 3850 can not play 2005 games at max details, so AGP is dropped. Also in order to take advantage of Athlon 64 X2 a strong video card is required, far better than anything available on AGP.
Reply 362 of 370, by AlexZ
In Chapter 2 I'm hoping to see Command Rate 1T working with 3GB DDR400 RAM and GTX 280. Ideally a 2.2Ghz CPU, 1MB L2 cache not essential as there are many CPUs out there with 512KB L2.
When I tried GTX 285 in s754 the performance uplift was minimal, like 1fps, the system is heavily CPU bottlenecked. These more powerful GPUs are a good fit for s939 X2.
GTX 570/660 should also work well, but require the latest driver due to regressions in period correct drivers for dx8 in Windows XP. They are super cheap, nobody wants them.
Pentium III 900E,ECS P6BXT-A+,384MB,GeForce FX 5600, Voodoo 2,Yamaha SM718
Turion 64 MT-40@2.4Ghz,Gigabyte GA-K8NE,2GB,GeForce GTX 275,Audigy 2ZS
Phenom II X4 965,Gigabyte GA-MA770-UD3,8GB,GeForce GTX 780
Vishera FX-8370,Asus 990FX,32GB,GeForce GTX 980 Ti
Reply 363 of 370, by nd22
Unfortunately my GTX 280, even after changing the memory pads and putting fresh MX4 refuses to run under 80C under load and turns the whole system turns into a furnace! I can not even touch the card after shutting down the system - I do not remember anyone complaining of temperature problems with this card! Geforce 200 series is the last series that can use forceware 197.77 - any later driver messes up with the games!
I am now trying to investigate the command rate with 4 1gb corsair 3500LL pro memory modules but first I must overcome the video card problem.
Reply 364 of 370, by SlowA
nd22 wrote on 2026-08-14, 08:47:
Post the feedback here definitely; I was planning to put 4x 512MB BH5 UTT on my rig.
Reply 365 of 370, by AlexZ
197.77 shouldn't be strictly required, as I said you should be able to use newer GPUs as long as you use one of the last drivers for Windows XP. Early 2xx drivers were broken for early Windows XP games and not fixed for a very long time. So instead of GTX 280 you should be able to use super cheap GTX 660.
If GTX 280 overheats even with 100% fan and repasting then there is something wrong with the card. Some GTX 260 came with 2 fan design, the heatsink may fit on GTX 280.
I seriously doubt 4x 1gb corsair 3500LL will work at Command Rate 1T. You will probably need to do binning for your 1GB and 512MB sticks for frequency/timings on another board so that you don't risk your precious Abit board, similarly to what I did with Qimonda. It's pretty simple - find one good stick then do a quick test which other stick works with the same frequency/timings/1T (just boot/quick 10 minutes memtest). Always default voltage. Then the best sticks may work. You will use them at DDR400 in Abit.
Reply 366 of 370, by nd22
In part 2 I will evaluate the performance rating of Athlon 64 X2 as I got all the models.
For now let's concentrate on Part 1: comparison of different PCI-express platforms for socket 939 using Athlon 64 X2.
While there are many boards with different chipsets available for socket 939 the most important player is NVIDIA.
VIA has 2 chipsets supporting PCI-express: K8T890 and K8T900. K8T890 is the swan song of VIA chipsets. It appears on numerous boards and is the only PCI-express chipset from VIA to be manufactured in large quantities. K8T900 is not implemented in any boards, nobody was interested in VIA anymore by this point.
A new player appeared - ATI - which looks promising, however they experience severe problems with USB and SATA implementation - so severe that ATI used south-bridges from ULI to overcome this problem.
ULI made 2 chipsets supporting PCI-express: M1695 and M1697. These are the final chipsets manufactured by ULI before the company was purchased by NVIDIA. M1695 supports natively both AGP and PCi-express and the one and only model is ASROCK 939Dual-SATA2/VSTA - a collector's item because of its ability to run both AGP and PCI-express concurrently. M1697 makes an appearance on Epox and ASROCK boards, however by this time no enthusiasm remains for ULI.
SIS is still barely hanging in there - there are boards with SIS 761GX for socket 754 and AM2 (!!) but they are all low end, cheap models that one should not look for when building a socket 939 with an Athlon X2. SIS 756 has been used by Asus and again ASROCK in 1 model by each manufacturer. This also marked the end for SIS chipsets for AMD CPU's.
Unlike earlier AGP platforms when we have so many chipsets, the transition to PCI-express during the socket 939 years was accompanied by a drastic reduction in chipset manufacturers. Only 2 survived this tumultuous era: NVIDIA and ATI which ended up being purchased by AMD.
Reply 367 of 370, by nd22
Abit made no boards with ULI and SIS chipsets, but did manufactured an extensive array of models based on nforce4 and a select few ones on VIA and ATI platforms.
A. NVIDIA
Nforce4 is, until now, the star of both socket 754 and 939 with the best compatibility, performance and features. For socket 939 we got the regular nforce4 on KN8 (that you have already seen in chapter 1, part 2) and AN8 models. This have only SATA first generation (an artificial limitation imposed by NVIDIA for the purpose of market segmentation) so we switch to nforce4 ultra. From the hardware point of view standard nforce4, nforce4 ultra and nforce4 SLI are actually one and the same! Because nforce4 ultra has SATA second generation it will represent the green camp in this final battle on socket 939. Abit made quite a lot of models but many of them share the same PCB: KN8 ultra shares the same PCB with the standard KN8, AN8 ultra shares the same PCB with regular AN8 and fatality AN8 ultra; AN8 SLI regular and fatality version are one and the same board - having a different color scheme does not mean they are different at the PCB level; only KN8 SLI is manufactured on its own, unique PCB.
Reply 368 of 370, by nd22
Because it has SATA second generation, very good airflow and I want to brag about it on the forums 😀 I selected Abit fatality AN8 to represent the green team in this final standoff. A common misconception on the WEB is that this board has only regular nforce4 with SATA 150 and so on, like in this link on the retro web: https://theretroweb.com/motherboards/s/abit-fatal1ty-an8
Abit fatality AN8 has nforce4 ultra chipset with SATA 300 and accepts SATA SSD's and optical drives.
Reply 369 of 370, by nd22
The positioning of the main & auxiliary power connectors is very good, right on the edge of the board where they should be. Note that it has a 24 pin main connector which is excellent as you can use any modern PSU without any problem.
Reply 370 of 370, by nd22
You can also see in the image above that the chipset benefits from active cooling: on one side this is a good thing as nforce4 heats up quite a lot, on the other side the 3 40mm fans present on this board make a highly irritating noise that you will hear all the time unless you are wearing headphones! You can also see the Vitesse chip that represents the physical layer interface for the gigabit LAN controller integrated into nforce4.
