First post, by renejr902
( it's not the same than yesterday ) So, on this 486 motherboard, there's an Amikey-2 chip. One chip in socket award software giga-byte L4487111 1994-95. Two SIS chips. The larger one 85C471 9516 st sis 94' PFA0032, the smaller one 85C407 9442 pw edd142. 3 ISA 16-bit. 3 VLB. 4 SIMM memory. It's strange the bios chip has 28 pins and the bios socket has 32 pins. I cant find this motherboard and google ai too.
Thanks for help about the model
( i have problem with it too but for now i ask mostly help for the model, but you can read below the strange behavior, help with be appreciated, but i'm searching the modell to find the jumpers position )
( the motherboard has strange problem. look at this as a resume of my talking to google ai , a lot of copy paste... i tried all the day to get it working with a hdd and i have several hdd, with or without ontrack disk manager and without pc freeze: It's going badly. I even tried changing the GPU. Ontrack is installed, but it freezes at the end; the screen is black. But the hdd is still working with Ontrack. but I select and press the spacebar to insert a boot disk to transfer the system to C: because it doesn't have an OS but Either it freezes at startup of the pc after the memory ram count, or it freezes during the Ontrack instructions, or it reads the disk and a large green line appears on the screen with unreadable green characters at the top, graphical glitchs. I changed two other GPUs, and it still freezes. I changed my 4MB RAM stick for another one, and it still freezes. I even cleaned the same slot and cleaned everything.. I unplugged it for 30 minutes so it's going back to a new boot process and work better until next glitch or freeze.. It could be a misplaced jumper. We'll try to find the motherboard. The CPU jumpers are in the right place written on the board. i tried a lot of different simm 4mb, 8mb, 32mb, all works and dont change anything )
Reply 1 of 20, by renejr902
it does not like to read 1.44mb that works perfect in my others pc .
they are boot disk dos 6.22 that i insert when ontrack ask to push spacebar and insert a boot disk.the pictures are the reads of the disks
Reply 2 of 20, by BitWrangler
Typical causes are cache problems, in this instance maybe enabled on the board while chips absent, memory problems, since it is not changed by modules, something above 64kb (or POST should catch it) and below 4MB. (Otherwise 4MB might work fine) so one of the address lines either dirty in the simm sockets or a line scratched under the board or something.... ORRRRR the 14.318 reference oscillator has drifted off by a lot and floppy timing is screwed.... or timing to ISA bus FDC is disrupted.
Gonna see if I can dig out the board...
Reply 3 of 20, by renejr902
BitWrangler wrote on 2026-08-21, 03:17:
ok thanks a lot for this answer. I will try to put compatible cache if i have some over or from my other 486.
But most of time, the pc freeze after memory count.
i cleaned the simm 1 a lot
Reply 4 of 20, by BitWrangler
I think we are looking at one of these...
https://theretroweb.com/motherboards/s/qdi-v4s471-472p
Now is there still a cache RAM in the tag socket that's hiding under the drive cage/cables in your pics? Between VLB socket and CPU.
If there is, it might be bad or misconfigured. Some boards can work with a tag only.
Reply 5 of 20, by renejr902
it seems to be thos one exactly except the bios chip. maybe someone change the bios chip:
QDI
V4S471/472P
Reply 6 of 20, by BitWrangler
Oh yeah, yours says Gigabyte on it, which kinda suggests it didn't come in a QDI. That might explain failures. So probably want to ensure it has the right BIOS in it before anything else. Before the system configuration screen comes up on boot, the prior POST screen, there's a string describing the BIOS at the bottom of the screen, should be same or similar to one of the ones under the BIOS tab on the retroweb page.
Reply 7 of 20, by renejr902
BitWrangler wrote on 2026-08-21, 03:37:
see the string
edit: just froze after a: dir
Reply 8 of 20, by renejr902
it doesnt seem similar enough. i have nothing to write the bios to a chip. hmm.
I will check the cpu type jumpers. A lot of jumpers make the cpu type. The board has no cpu in it when i received it
i check the manual and the bios option are pretty much the same. it's looks like 95%+ similar.
But i think the fact that i have no cache chip is a problem.
Reply 9 of 20, by renejr902
I past the night on it. i removed the tag cache chip that was there. i removed all cache jumper. disabled every cache in bios. it loads faster. but same problem. i tried another multi i/o card, another floppy and ide cable, different floppy, same problem. i even prepare hdd with another computer , nothing still boot. and no possibility to read any files or them from floppy. boot disk never boot and maked strange caracters. 1 time on 20 it boots but froze and cant copy anything. i tried a 527mb hdd with 1023 16 63 and still does not work. and thid hdd was booting on another computer. I think I'm going to give up. i dont have cache for him. i dont have other bios rom. if you think the bios award chip is flashable with a program let me know. i dont want to buy stuff to flash it. Thanks if you have any idea
Reply 10 of 20, by renejr902
BitWrangler wrote on 2026-08-21, 03:28:
I think we are looking at one of these... https://theretroweb.com/motherboards/s/qdi-v4s471-472p […]
it was done. read my last post. thanks
Reply 11 of 20, by BitWrangler
Hmmm, it might be possible to hot flash a new BIOS into that chip, but that would need another motherboard that takes that size of ROM and also allows flash, I think that other 486 board you posted doesn't. It seems that this one might not run long enough for a flash to complete to do a flash on this board.
However, the chip needs to be confirmed to be a flash part not an EPROM or a mask ROM, which means peeling back the sticker and reading the part number. Jumper 73 next to the BIOS seems to be set in "flash ROM" position, which may have been for original BIOS, not this one. This one seems capable of getting as far as it does because it's at least the same chipset. Anyway, a quick and random thing to try is if jumper 73 improves behavior by being put to the other setting, that's a just about worth trying thing.
Anyway, if that is not a flash chip that could be hot flashed in another board, seems only way forward is to get a flashable chip, either new or salvaged from a dead board, hot flash the QDI bios to it and change it into this board.
Maybe someone else will have better ideas of what to do though.
Reply 12 of 20, by renejr902
BitWrangler wrote on 2026-08-21, 15:13:
Hmmm, it might be possible to hot flash a new BIOS into that chip, but that would need another motherboard that takes that size […]
I got.it working correctly perfectly after 15h hours of testing. I'm not sure what's make the difference, i did three things. 1. I exchanged the dx-33 cpu for a sx-25 cpu and i changed all jumpers correctly. 2. After that i remove the multi i/o isa card from the last isa slot at the bottom ( i tried before the 2 other isa slot too ) and i put it on a isa track that is a vlb slot with the brown slot at the end. This is the first slot of the board, the first of the 3 vlb slot. 3. i did change the bios again because i removed the vattery before and the bios was reset. i put the safest setting i could. ( the 1.7gb wirks now, i even succeed to use the ontrack disk manager floppy disk to configure it correctly. i copy games and files from my floppy disk on the hdd and all games runs correctly on the hdd.
What did get it working ? Number 1, 2 or 3 ??? Thanks for answer. I fear touch anything now 🤣. I have a few cache chips over in my stock. could they could be use:
14 pins MCM6264CP20 X3, 14 pins MCM6264CP25 X4, 14pins W24257AK-15 95100 X1 and 11 pins IS61C66-20N 9138 ISSI X3. or i can take half of my other vlb 486 cache chip 4 of the 8 chip. and i need a tag chip
Because i suppose a 486 with no external cache should be very slow in games, doom 1+2, nfs, jazz jackrabbit, duke nukem 3d, keen 4 to 6...
Thanks for answers
Reply 13 of 20, by BitWrangler
Awesome, glad it's going enough to do something with. With no cache Doom and Duke3d will be awful, but the others should be okay, they only need 386 or fast 286.
I think I see the board the BIOS belongs to https://theretroweb.com/motherboards/s/chicony-ch-471b
Which as you can see has quite a different layout. Is is possible that some of the jumpers are more or less "software defined" by the firmware and thus do something different than what it is thought they do, because the other board used that input on the chipset for something else.
However, a flash could be a possibility on that board now it's running well enough.
I think the BIOS got lost somehow, corruption or chip removed and a previous owner found a chip off a gigabyte board, couldn't find details of the board, a few years before retroweb info was very scattered and hard to find, and guessed at this other SiS 471 board and tried that BIOS, and who knows if he even got as far as you did.
Some guesses why 33 maybe doesn't work.... possible flaky jumper pins or caps on the speed setting, if one or the other is making bad contact, CPU might be trying to jump to 40 or 50mhz and crashing. Possible wrong setting of the Vesa 33Mhz wait state jumper, which usually doesn't matter much until you've got a VLB card in, but maybe if the board is a bit marginal it does. Also the right feature settings for the DX might be mapped to the wrong pins by this firmware, SX CPU are very simple and like a default.
Reply 14 of 20, by renejr902
BitWrangler wrote on 2026-08-22, 03:42:
Awesome, glad it's going enough to do something with. With no cache Doom and Duke3d will be awful, but the others should be okay […]
everything works great until now. i put all my games and software and utilities on the hdd with another pc and adapter. everything works so far even the sound card and i put my 32mb ram simm in it. ( i have 2 x 32mb, but 64 mb for a 486 25 or 33mhz is strange and i dont want problem with 64mb )
1. So do you think it's the cpu or the 2 bottom isa slot that was the problem or other things ? i can put the 33mhz back and change jumper again.
The VESA is set at <=33.
2. i have copied on the hdd the uniflash 1.40 and both firmware. the J73 is is not flash position. Can i put it to Flash and try to flash the firmaware or can i corrupt everything if the chip is not flashable ? and i dont know which to flash : mv4-v4.amw.amw or Q13G.ROM ? and if uniflash need patameter let me know too Thanks for answer.
Duke nukem 3d runs very bad 🤣
Doom runs bad enough worst than my 386 DX-33 with cache 🤣 ! I'm surprised it runs that bad with a cirrus logic vlb card 5428, i will put 2mb for better speed. I understand it's only a sx-25 with cache. I will try to put back the 33mhz
THANKS SO MUCH FOR ALL YOUR HELP. It is very appreciated !
Reply 15 of 20, by renejr902
It can't be flashed i think without special equipment, i removed the sticker, i saw a small windows on it, see the model i note it:
m27c512-I5fI B88AQ 933IC ST Singapore
I have a bios chip too check the picture, a AMI bios 486 chip, but it was on a board without vlb
Reply 16 of 20, by renejr902
I just found the problem. It doesn't work correctly with the 486 DX-33 CPU.
But i dont know if the the cpu is defective or the motherboard have a problrm with and the 33mhz things. The jumper are correct. The cpu has one leg a little bent, but its not broke and it enters easily.
Do you have a idea ? Thanks
Reply 17 of 20, by renejr902
I tried changing the vesa 33mhz and wait jumper and it changes nothing
But i tried running the 486 DX-33 CPU at 25mhz innstead of 33mhz with the DX jumper enabled as a 486 DX25 CPU and it seems to work perfect.
So is it a cpu problem or the motherboard doesnt want to run at 33mhz ? or bios problem because of bad chip
Reply 18 of 20, by renejr902
Problems resolved. I'm disappointed of myself. i build several 486 in my life...
The 486 DX-33 CPU was running at 3.45v instead of 5v. The manual was not clear about how to put it in 5V. I thought it was done automatically. i had to put jumper on U50 jumper 3-6 and 4-5 close. Thanks for everything and your support and help, it was very appreciated !
