First post, by Compaq Sniffer
Hello, I work for a certain massive entertainment chain and I am their tech. I love to work on monitors and older computers. Anyway, I have this 7800 GS AGP card, and it is dead. The fan spins up but there is no display. This card came out of a SEGA Let's Go Jungle! The GPU that is currently in the game is starting to artifact.
The GPU currently in the PC is a BFG branded card and it is from around bumpgate era. I don't know if that's the cause, but I would like some input on that.
The dead GPU seems to have a cap that is slightly bulged. I haven't taken it off the board, but it is bulging compared to the slightly working BFG card. My question is if that cap could be causing the no video issue. What does the cap do? It's specifically the purple sanyo cap, the one with the purple plastic wrapping. It is a 510uF, 4V cap.
Is there anything that I can do to fix either card?
Also how do I attach images on this website? I'm used to VCF forum.
Reply 1 of 5, by Unknown_K
Are those polymer capacitors? If so, I never seen one bulge is it shorted/exploded?
Reply 2 of 5, by momaka
Compaq Sniffer wrote on 2026-08-21, 22:12:
Maybe.
The AGP 7800 and 7900 series use G71 GPU core, IIRC, and those are from the bumpgate era indeed. A re-heat of the GPU (be it with the same temperatures as a proper reflow or a lower temperature - it will vary between failed GPUs) can sometimes bring these back to life temporarily - with temporarily being anywhere from a few use sessions to a few years or more.
With the bumpgated GPUs, it's all about temperature and number of hot-cold cycles of the GPU. Generally, these GPUs can last much longer when...
- they are kept at lower temperatures, both idle and full load - even reflown ones. If you can keep them under 55-60C under full load, that would be better (but it's difficult and requires an aftermarket or self-made cooler or water cooling to do this.)
- the number of on-off cycles and idle-to-full-load cycles is reduced.
That being said, post images of both cards please.
Some "no-name" 7800 cards used crappy Sacon FZ electrolytic capacitors that look very much like polymer capacitors... but aren't!! In fact, these Sacon FZ (can be recognized by the "FZ" on their first like, followed by a random 2-digit number) are some of the worst electrolytic capacitors in existence.
The BFG card should be safe from these, as BFG generally used nVidia's reference design and reference-spec components. But the no-name Chinese-built cards very regularly use Sacon FZ or other crappy brands. So it would be good to see pictures of both cards, just in case.
Log in and either click on the quotation marks of any post you want to quote or click on "Full Editor and Preview" at the bottom of the page. This will take you to a new page with a post/text editor. Right below the text box is a button/line that says "Attachments". click on that and upload your pictures. (Hint: make sure to select a proper license for your images, or your post may not post until you do that.)
Reply 3 of 5, by rasz_pl
BFG Nvidia GeForce 7800 GS OC 256MB GDDR3 AGP BFGR78256GSOC does indeed have one violet plastic wrapped electrolytic https://theretroweb.com/expansioncards/s/bfg- … gs-oc-256mb-agp + two others near molex. Replacing those is an easy cheap diagnostic step
As momaka said cant really fix bumpgate GPU once it goes, just temporary bodges with heatgun.
Reply 4 of 5, by Compaq Sniffer
momaka wrote on 2026-08-22, 12:42:
Maybe. […]
Maybe.
It seems my images are too big everytime I try to attach them.
I attached the dead video card picture but I don't know if it'll show or not it's giving me this error:
"Couldn't recompress the image to the maximum file size of 2 MiB. Please manually recompress the image."
If the image does show up it's that purple cap that's slightly bulged, it's not the solid aluminum cans, but the ones that looks like a EL.
Reply 5 of 5, by Compaq Sniffer
Compaq Sniffer wrote on 2026-08-31, 18:30:
It seems my images are too big everytime I try to attach them. […]
Maybe. […]
Maybe.
I wanted to mention that if you look up the 7800gs on Google, it is the stock card that comes up on Tom's hardware:
https://www.techpowerup.com/gpu-specs/geforce … 00-gs-agp.c3732
Mine is the same as that one. That one is the card that doesn't display video and has a bulged cap.
The one that is artifacting is the BFG GPU. The bfg is the OC card with the blue solder mask and copper heatsink. Like this one:
https://ebay.io/m/1f6EhR
Just wanted to make it clear these are two different gpus with 2 different problems.
