First post, by Qwseyvnd
Hi every users in this Vogons.Org.
Do anyone knows where to download Android 1.0 before the 1.1 Petite Four?
Addin that I could not download the elderly files before "trixie" Debian such as 3, 4, 5, 6, 7, 8, 9 "Stretch", 10, 11, 12, and 13.<3.3. While almost completed 13.4.0, 1 of around 40.000 packages not completed. That is not acceptable.
Greetings from Qwseyvnd.
Reply 1 of 2, by LSS10999
Qwseyvnd wrote on 2026-04-03, 20:13:
You need to check the Debian Archive (archive.debian.org). Mirrors normally don't keep old Debian versions once they reached EOL so for systems still in active use you need to manually point the apt sources to there. Replace all occurrences of both "security.debian.org" and the mirror you're currently using to "archive.debian.org" in your apt sources lists and you should be able to make apt usable again.
I think Google should have an archive about everything Android somewhere... though I cannot be sure about very ancient Android versions, as my very first Android device used 1.5 (Cupcake).
Reply 2 of 2, by Qwseyvnd
LSS10999 wrote on 2026-08-03, 08:46:
OK, I planning to trying that connect till archive.debian.org.
