First post, by ntalaec
Do you know any software for DOS which can change the brightness or gamma of the screen? My netbook doesn't have any button to do it.
Edit: one found.
dostools.zip (read jtchip post)
https://github.com/karcherm/dostools/releases
Reply 1 of 15, by theelf
And what is model of your netbook?
Reply 2 of 15, by aVd
Hi, @ntalaec,
The only similar thing for DOS, that I know, is DIMMER.COM by Douglas Boling and Jeff Prosise. You can download it from here or here.
I like the quieter planets, this one became pretty noisy 😀
Reply 3 of 15, by ntalaec
theelf wrote on 2026-07-19, 14:22:
It's a Sony VPCW11S1E
aVd wrote on 2026-07-19, 19:21:
Hi, @ntalaec,
Thanks, but it does not work in this computer. The computer hangs when I try to load the application.
There is an utility for DOS for an industrial component which could do the job, but I can't find a download link:
PowerStation Contrast/Brightness Utility
I have also found an utility which allows gamma change but no brightness:
https://www.sac.sk/download/utiltext/brght092.zip
There is also a port of SVGATextMode for DOS that can change frequencies, gamma and text modes but again no brightness:
https://www.ibiblio.org/pub/micro/pc-stuff/fr … 9_16rc1-dos.tgz
Reply 4 of 15, by jtchip
From the T430 thread, you said this netbook has an Intel 945GM Express. Searching around, there is this post on setting the backlight brightness manually using setpci in Linux https://bugs.launchpad.net/ubuntu/+source/xse … 617/comments/19:
# lspci | grep VGA
00:02.0 VGA compatible controller: Intel Corporation Mobile 945GME Express Integrated Graphics Controller (rev 03)
# setpci -s 00:02.0 F4.B=66 (a value between 00 and FF, where FF is 100%)
This is an Intel Gen3 GPU. The author of that post has a Samsung NC10. I tried that on my ThinkPad T400 which has a Gen4 GMA 4500MHD and shows up as:
00:02.0 VGA compatible controller [0300]: Intel Corporation Mobile 4 Series Chipset Integrated Graphics Controller [8086:2a42] (rev 07) (prog-if 00 [VGA controller])
and the setpci does work.
Dropping the =<value> displays the current value. On the T400, the hotkeys provide 15 steps (and the hotkeys always work, even in Linux and DOS), the brightest corresponds to FF, second brightest is A6, and the dimmest is 06. Setting it to 0 with setpci will turn off the backlight.
For DOS, mkarcher has written dostools which can be found here: https://github.com/karcherm/dostools/releases and includes a similar PCI.EXE utility.
First check:
C:\DOSTOOLS>pci 00:02.0
00:02.0: id 8086:2a42, class 03/00/00
INTA -> IRQ11
that the device at that PCI bus location is class 03, i.e. VGA compatible controller, and the PCI vendor is 8086, i.e. Intel. Your PCI device ID will be different, probably 27a6 instead of 2a42.
Then try reading the value and changing it:
C:\DOSTOOLS>pci 00:02.0 F4
00:02.0 - f4 is 18
C:\DOSTOOLS>pci 00:02.0 F4=2a
If it works, it should change the backlight brightness.
As always, try at your own risk. I checked the official 945G and 82G4x datasheets and the F4 register is marked reserved or not documented, respectively.
Reply 5 of 15, by ntalaec
It works! Thanks jtchip.
My netbook don't have an Intel 945GM Express (945GME) but an Intel 945GM (945GM). My device ID is 27ae. I'm not sure if it also changes the gamma because with pci.exe 00:02.0 F4=01 it's barely possible to see what is on screen. F4=00 does not seem to power off screen but to remove all brightness and it's not possible to see anything.
The only problem I see is that only makes changes in memory not in BIOS, so every reboot I have to change this setting again. It's possible to change this value in BIOS?
Reply 6 of 15, by NeoG_
ntalaec wrote on 2026-08-16, 08:21:
You can put it in your autoexec so it runs automatically
98/DOS Rig: BabyAT AladdinV, K6-2+/550, V3 2000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, SB16-SCSI, PicoGUS, WP32 McCake, iNFRA CD, ZIP100
XP Rig: Lian Li PC-10 ATX, Gigabyte X38-DQ6, Core2Duo E6850, ATi HD5870, 2GB DDR2, 2TB HDD, X-Fi XtremeGamer
Reply 7 of 15, by ntalaec
NeoG_ wrote on 2026-08-16, 08:27:
Yes, I did that. But it's possible to change value in BIOS? BIOS screen and booting before this line in AUTOEXEC.BAT it's at full brightness.
Reply 8 of 15, by jtchip
You're welcome. I looked up the original Linux bug and https://bugs.freedesktop.org/show_bug.cgi?id=20963#c82 says ("the method" referring to setting the F4 register):
The method this driver is using is no way Samsung specific, it's just the old legacy method. This is applicable to *all* intel chips (i830 and up). However, the driver should also program the native method (also i830 and up).
so that means it should work on the following Intel mobile chipsets:
  • Gen2: Extreme Graphics (i830M), Extreme Graphics 2 (i852GM/854/855GM)
  • Gen3: GMA950, GMA3150
  • Gen4: GMA X3100, GMA 4500MHD
OK, 27a6 appears to be the display controller at 00:02.1, 27ae is a "Mobile 945GSE Express Integrated Graphics Controller".
I don't think it changes the gamma, it just controls the brightness of the backlight. At F4=00, the screen is still powered on, only the backlight is turned off, it should be possible to see what's rendered on the screen if you shine a bright light on it.
No, at least not easily. That will require BIOS modding, at least disassembling it, finding where the backlight register is set and patching it to a different value, recomputing the checksum, and flashing it. If it doesn't work, or if it leaves the computer unbootable, then that means reprogramming the EEPROM with an external programmer.
Reply 9 of 15, by ntalaec
jtchip wrote on 2026-08-16, 23:58:
This does not sound very safe to do. But there is an utility (SANE) which claims that can reset VGA BIOS values. Maybe can change this setting too.
Reply 10 of 15, by igully
ntalaec wrote on 2026-08-17, 11:04:
It resets to VGA BIOS default values, it does not change them.
It seems BIOS modding is required for what the user wants.
Reply 11 of 15, by jtchip
Back to the original post:
ntalaec wrote on 2026-07-19, 09:29:
The user guide says on page 27 "Using the keyboard":
  • Fn + F5/F6: brightness control: Changes the LCD brightness of your computer screen.
Does it not work on your netbook, or does it just not work in DOS?
Reply 12 of 15, by ntalaec
igully wrote on 2026-08-17, 21:44:
It's necessary to completely flash the BIOS to change screen brightness setting? It's just a DOS limitation or any Windows application that control brightness needs to do it?
jtchip wrote on 2026-08-17, 22:28:
The user guide says on page 27 "Using the keyboard": […]
It does not work in DOS.
Reply 13 of 15, by NeoG_
ntalaec wrote on 2026-08-18, 09:41:
The way it works on newer laptops work is the keyboard button presses are intercepted by a software layer (either provided by the OS or a driver) and the software layer sends the commands to the hardware to make the changes. That software layer doesn't exist in DOS. The BIOS would need to be modified to send those same brightness commands on startup where it currently doesn't.
Reply 14 of 15, by ntalaec
NeoG_ wrote on 2026-08-18, 10:13:
But in Windows this software does not flash the whole BIOS, it only changes brightness value setting. So the problem is that in DOS it's not possible to know where to write this changes? Or there is a control in BIOS to disable this area from DOS?
Reply 15 of 15, by jtchip
Let's get back to basics. To check or modify the current brightness of the backlight, you read or write, respectively, register F4 of the Intel Gen2-4 GPU PCI(e) configuration space.
In Windows, there is a utility provided by Sony or Intel that listens for the hot keys so that it can change the current brightness of the backlight:
  • Hot key -> Windows (userspace) utility -> Windows (kernel) driver -> write register F4
In DOS, there's no such utility but you can use low-level utilities that can write to PCI(e) configuration registers like PCI.EXE to perform a one-off change.
At boot, the video BIOS likely writes FF to the aforementioned F4 register to set the backlight to maximum brightness. Therefore to change the backlight brightness at boot you have to change the video BIOS.
(Mods, please move this to Marvin - Video, thanks)
