EAX appreciation thread
Reply 1220 of 1253, by sharangad
AndreaColombo86 wrote on 2026-08-26, 08:20:
So if I wanted to, say, impress a friend who’s never experienced EAX, Battlefield is where it’s at, pretty much. I’m gonna try Quake 4 for sure as I’ve wanted to play that for a while now.
Prey 2006 is quite good as well. I need to try out the recently rediscovered quake 4 expansion to see what it sounds like. Then there's doom 3, a perennial favorite, though it's a bit exaggerated.
Dreamfall Chapters is another one. It's an 3D adventure game and might not be everyone's cup of tea, but it had very good sound, EAX4 I think. More than a decade later the story continued in Dreamfall Chapters, but that only had plain jane stereo:
Dreamfall Chapters: https://youtu.be/MufiGxYLHEY
https://www.youtube.com/@sharangadayananda\
https://patreon.com/Rready
Reply 1221 of 1253, by Joseph_Joestar
Absolutely. For me, Battlefield 2 / 2142 represent the pinnacle of EAX and CMSS-3D. Especially when using headphones.
Quake 4 is very good as well, but I feel that it sounds slightly better on 5.1 surround speakers. Simply because it makes such good use of the subwoofer for explosions. Probably through EAX PurePath.
My retro stuff
Reply 1222 of 1253, by AndreaColombo86
Thanks, guys.
Is BioShock’s implementation good?
Reply 1224 of 1253, by Joseph_Joestar
Since people have been asking, here are my personal top 5 EAX games. Of course, this is just my subjective opinion, and everyone is free to post their own list.
1. Battlefield 2 / Battlefield 2142
These two games share the top spot, as the EAX implantation is equally good in both. I've talked about them many times, but the key takeaway is that they use EAX 5.0 and CMSS-3D to their maximum potential, as the developers have worked closely with Creative Labs engineers to ensure that. See here for more details. Positional audio is exceptionally good, and all EAX effects (reverb, occlusion, reflection etc.) are used to their fullest. They also make excellent use of the X-Fi's 128 hardware voices, as seen in this test.
2. Prey (2006)
Another game that makes fantastic use of EAX 5.0 and CMSS-3D, which is especially noticeable because of the unique environments that you get to explore. Due to how gravity works in this game, enemies will often attack you from above, below or anywhere else in 3D space. The game's positional audio reflects this beautifully, especially when using headphones. More info about how the developers used EAX in Prey can be found here.
3. Quake 4
This is another EAX 5.0 title that makes superb use of the tech. In particular, I was impressed with how realistic the in-game explosions sound here, especially when using 5.1 surround speakers. The subwoofer is used to its full potential thanks to EAX PurePath, and positional audio is excellent too. There are also some standout effects, such as when a grenade explodes near you, it will temporarily dull your hearing. A detailed summary of the EAX implementation in Quake 4 can be found here.
4. Thief: Deadly Shadows
This game uses EAX 4.0 in a great way. Every EAX feature gets the spotlight here, including Environment Morphing and Multi-Environments, which help to realistically model the soundstage of the levels. This is particularly important for a stealth game, so the developers handled it with great care (more info here). You will visit castles, cathedrals, caves and clocktowers in this game, and EAX really helps with bringing those places to life. And of course, there's the famous horror-themed mission called "Robbing the Cradle" which definitively needs to be experienced with EAX 4.0 and a nice pair of headphones. Beware of jump scares.
5. Splinter Cell: Chaos Theory
Another stealth game which makes excellent use of EAX 3.0 for its levels. This is evident from the very first mission. For example, try walking into one of the tents there, and listen to the raindrops hitting the fabric. With a good pair of headphones, it sounds like you're actually standing inside that tent in the rain. Furthermore, during that mission EAX is especially noticeable in the caves and inside the lighthouse itself. And it only gets better from there.
My retro stuff
Reply 1225 of 1253, by Joseph_Joestar
A couple of snippets from the Prey EAX page that I linked to earlier:
Creative Labs wrote:
Lead audio designer, Ed Lima, worked closely with Creative to ensure optimal support for the latest Sound Blaster X-Fi technologies. Up to four reverbs are processed simultaneously by the sound card while panning and positioning them around the player. Full support was also added for low pass filtering effects (occlusion and obstruction) to help create a muffled effect whenever a sound is generated behind a door or portal. For example, all sounds behind closed doors or on the other side of portals are low pass filtered (each additional closed door or portal between the player and the sound adds an additional amount of low pass filtering).
Because audio is not fixed into a speaker configuration until the final playback stage, Prey audio played through the OpenAL API can be virtualized to surround sound in a far more meaningful way. The audio reaching the card from the game is delivered with all its positional information intact thereby allowing the headphone or stereo speaker virtualization algorithms to produce highly convincing surround sound over stereo playback equipment.
Simply select X-Fi CMSS-3D and set your speaker settings to headphones and Prey will sound as good, if not better, over headphones as it does on 7.1 speaker systems. The wall walking element of Prey is further enhanced by the improved elevation effects offered by the advanced HRTF algorithms of X-Fi CMSS-3D.
As noted before, this game features many environments where gravity works in unusual ways. This makes its soundstage very unique, especially when using the X-Fi CMSS-3D Headphone mode.
My retro stuff
Reply 1226 of 1253, by AndreaColombo86
Is Max Payne 2’s implementation anything to write home about?
Reply 1227 of 1253, by Joseph_Joestar
AndreaColombo86 wrote on 2026-08-31, 08:48:
It's been four years since I last replayed that game, so my memory is a bit fuzzy.
But from my notes, positional audio was very good, and I liked the occlusion effects on sounds coming from behind closed doors and such. Can't think of much else at the moment, but maybe someone who has played this more recently could chime in.
My retro stuff
Reply 1228 of 1253, by sharangad
The X-Fi demo disc that was posted here earlier, has video demos for each EAX5 effect (and pretty much every feature) in the ProgFilesx86\Creative/SBOSB Demo/demoHR folder. They're WMV HD videos and will play back with legacy Windows Media Player in Win 11. They won't playback within the demo app because the player app is Flash based.
Here're the video demos on Youtube:
https://youtu.be/izYd5yOp3yM (normalised an on X-Fi)
https://youtu.be/eaANfMpjifI (Audigy RX, not normalised).
Reply 1229 of 1253, by weilun777
Sombrero wrote on 2024-05-01, 11:59:
Positional audio isn't optimal with 2.0 setup as you can imagine, but can still add depth to the sound and things like occlusion […]
Positional audio isn't optimal with 2.0 setup as you can imagine, but can still add depth to the sound and things like occlusion effects/reverb work just fine.
As for how pleasing/weird it is is subjective and can be game dependant. I used to use 2.0 speakers back in the day with an integrated sound chip that supported EAX 2.0 and I grew to dislike EAX with a vengeance, I remember feeling like it usually made games sound overly echoy and somehow distorted the sounds coming from the sides/behind.
Then years later I went and got an X-Fi card and suddenly realized I liked EAX more often than not. I do use headphones these days but that only affects positional audio, not the effects, so either my preferences have changed or that sound chip butchered the effects somehow. WDM drivers on WinXP and I was playing Win9x games that expected VxD?
So I'd say give it a go, SB Live!/Audigy/Audigy 2 cards are plentiful and inexpensive.
I don't like EAX too! because it often makes the echoes feel weird.
Reply 1230 of 1253, by Joseph_Joestar
sharangad wrote on 2026-09-04, 18:36:
Nice work with uploading those!
I'm not 100% sure, but I think some of these videos might even support 5.1 audio. If so, they can also demonstrate how these effects apply to surround sound.
My retro stuff
Reply 1231 of 1253, by sharangad
Joseph_Joestar wrote on 2026-09-05, 04:33:
They do; I forgot to normalize the clip and they were captured on an Audigy so what you're hearing is the rx's cmss. Yeah they're in surround, very prominent surround.
I should probably post another capture on an x-fi.
(Update: I've added a link to a normalised version https://youtu.be/izYd5yOp3yM)
Reply 1232 of 1253, by AndreaColombo86
Is anyone in a position to record a video showcasing the EAX Occlusion effect in Baldur’s Gate 2?
A friend is trying to get DSOAL fixed so that it restores that effect, and including a video in the bug report would go a long way.
Reply 1233 of 1253, by Joseph_Joestar
AndreaColombo86 wrote on 2026-09-15, 15:08:
I don't have the equipment to do video capture, but I have documented the test process here a few years ago.
Feel free to use that, if it helps.
My retro stuff
Reply 1234 of 1253, by sharangad
I dont have a win9x machine with an Audigy anymore. My audigy 2 zs died recently or to be more specific, the machine bsods during boot or driver installation. I'm running a vortex 1 card at the mo.
Reply 1235 of 1253, by sharangad
Joseph_Joestar wrote on 2026-09-15, 15:25:
Does anyone have any saves from bg2 that I could use for this? I'm going to try setting up the audigy again tomorrow, maybe run both a vortex 1 and the audigy. The audigy might be dead, but I can try.
Reply 1236 of 1253, by Joseph_Joestar
sharangad wrote on 2026-09-18, 15:39:
The relevant save is attached to the post linked above.
My retro stuff
Reply 1237 of 1253, by Zoomer
I tried reproducing the occlusion effect demonstrated in your post, Joseph_Joestar, with your save on GOG's BG2 with Alchemy and X-Fi Titanium HD. Even though Environmental Effects are enabled and I'm getting 3D speaker panning just as per your audio recordings, I'm not getting that occlusion attenuation unfortunately.
If I remove the Alchemy's dsound.dll, I'm getting stereo sound only. So it seems that HW 3D sound is being emulating properly, but no EAX effects are applied, which is weird (but in-line with that VxD vs WDM thing). I've also tried moving the character around, still no occlusion anywhere.
MB: Asus P3B-F 1.03 (2x ISA)
CPU: PIII-S 1.4GHz/VIA C3 800MHz
RAM: 256MB PC133
Video: GeForce 4600Ti/Voodoo 5 5500/Voodoo 3 3500 for DOS Glide
Audio: SB16 OPL3 + Audigy Platinum Ex
OS: Windows 98
Reply 1238 of 1253, by sharangad
Zoomer wrote on 2026-09-18, 17:10:
I think the consensus is that it only works on windows 98 with vxd drivers, so no xfi, only live and audigy. This also means it won't work on xp and even on win98 it needs vxd drivers and won't work with wdm ones.
Reply 1239 of 1253, by Joseph_Joestar
Sigh, I'm starting to wonder if people are actually reading my posts or just skimming through them without comprehending what I wrote. In Baldur's Gate 2, occlusion needs VxD drivers in order to work properly. Meaning, the game needs to be played under Win9x, since newer Windows versions don't support VxD drivers. The sole exception to this seem to be SBLive cards, which can provide occlusion in this game when using specific versions of WDM drivers under WinXP (as noted here). Anything newer than that cannot be used for the purposes of this test.
Anyway, I'm done explaining this any further. I simply don't care about the issue enough to spend more of my time and energy on it.
My retro stuff
