Reply 2640 of 2643, by RetroGC
Roland User wrote on 2026-08-26, 10:42:RetroGC , your offer not mean sense because for this work , you need have GS compatible soundfont or GS compatible MIDI Device , […]
RetroGC , your offer not mean sense because for this work , you need have GS compatible soundfont or GS compatible MIDI Device , if this remove to SFX Kit 56 key how you offer , then when users will be play MIDI on standard soundfont whitch General MIDI compatible , they not be hear gunshot because in Standard Kit this sound absent ) because how I known , this sound available only in SFX and CM 32/64 drumset , in all other drumsets this sound if not considered variants drumsets of SC-88 Pro and later , this sound not provided of standards )
and also , how be if gunshot patch mean :
0 128 Gun Shot
1 Machine Gun
2 Lasergun
3 Explosion
4 Eruption
5 Big Shot
6 Explosion 2
you get move gunshot to SFX , but how be if patch nubmer 127 / 128 , and bank number not 0 ? What do if this variant ? )
There's few missunderstanding here. I was asking this just for some midi files derived from vgmtrans. As you know that kind of midi files have an associated sf2 palette and usually drum's channel is on gunshot instruments (at least on dragon quest 6). It's not intended for real midi files using that sound. Aldo
