First post, by kolderman
So I've been wanted to do this for years, but lacking any knowledge of delphi was kind of a barrier. But then I discovered my supergrok subscription came with fairly generous credits for Grok Build (the terminal UI coding agent), and I thought what the heck let's give it a try. So after throwing two months worth of credits at it, I finally have the DFend I always wanted.
* New and improved things
- DOSBox-X and DOSBox Staging detection and support (naturally).
- Full support for detection and selection of pixel shaders/presets.
- Support for fluidsynth as a midi device - gain and soundfont path.
- Vsync/inactive screen option.
- Direct Windows MIDI interface detection.
- Rebuilt in RAD 12 with Unicode and modern Windows support.
- eXoDOS support for metadata, media and game import.
- Autoplay ambient music for games with soundtracks.
- Dozens of renamed/removed/changed dosbox config options updated in the config generator.
* Stuff I got rid of
- The classic profile editor.
- Bundled DOSBox classic and FreeDOS.
- Inbuilt video player (audio player remains, upgraded to use bass.dll).
- Numerous bug fixes and issues corrected.
* Stuff I would like to do if I have time
- At least one working metadata update URL (harder than it seems, most have gone behind API keys or paywalls).
- MT32 options support (rom/soundfont paths).
- 64-bit (would be nice).
- WinXP support (maybe one day, possible in theory with deep hacks of the delphi RTL).
Drop any comments or issues here or the github issues page. Note this will install alongside any existing D-Fend installations without conflict. You will have to copy over profiles manually as there is no import tool yet.
https://github.com/cyberfox1/dfendx/releases/tag/2.0.0
Reply 1 of 16, by IIGS_User
Great to see this again. 😀
Klimawandel.
Reply 2 of 16, by SedrynTyros
Nice!
Reply 3 of 16, by KainXVIII
Is it really vibe-coded?
Reply 4 of 16, by kolderman
KainXVIII wrote on 2026-08-04, 18:55:
Vibe-coded - me sitting back talking into a mic while watching YouTube? No.
Did I use Grok as a tool to make 95% of the actual code changes while reviewing them and calling out it's bullshit 50% of the time? Then yes.
Reply 5 of 16, by SedrynTyros
Doesn't matter how it was coded if it actually works.
Reply 6 of 16, by kolderman
Latest release
- MT32 support for DOSBox Staging and X (model/romdir/gain).
- Title image side panel to display a selected image per profile.
- Restored TheGamesDB as a metadata source (requires API key).
- Upgraded ogggenc2 and mkdosfs utilities to latest versions.
- Switched to WIC for most image operations (much faster scaling).
- Refreshed list of Search Links with active websites.
- Langauge translation updates.
- Added olivetti and pc3270 machine types (DOSBox-X only).
https://github.com/cyberfox1/dfendx/releases/tag/2.1.0
Reply 7 of 16, by zapbuzz
This is good for modern windows i've tested it and it works well done.
I am a ritual user of Dosbox in Windows Millennium on my retro PC, however.
Reply 8 of 16, by kolderman
zapbuzz wrote on 2026-08-09, 06:26:
Thanks for the feedback, appreciate all the feedback and comments I can get from people here.
Reply 9 of 16, by dor123
What is DFendX? A sequel to D-Fend Reloaded?
DOSBox 0.74-3
D-Fend Reloaded 1.4.4
DOSBox Game Launcher v0.97
DFendX 2.1.0
Windows 10 Enterprise 64-bit version 22H2
Reply 10 of 16, by kolderman
dor123 wrote on 2026-08-09, 14:30:
Its a fork of Reloaded, which hasn't been worked on in over 10 years, so you can think of it as a modern sequel or successor, yes.
Reply 11 of 16, by dor123
But I can't download it.
DOSBox 0.74-3
DFendX 2.1.0
Reply 13 of 16, by dor123
Thanks you very much.
DOSBox 0.74-3
DFendX 2.1.0
Reply 14 of 16, by kolderman
Latest release - Version 2.2.0
- Initial Support for DOSBox Pure Unleashed
- Profile editor: frame invalidation when dosbox kind changes.
- HTML Help is now rebuilt from markdown wiki (English only).
- Renamed FluidSynth to Soundfont in UI for consistency.
- Bypass eXoDOS config.com to preserve settings for eXoDOS games.
- Fixed a Startup crash with large number of profiles.
https://github.com/cyberfox1/dfendx/releases/tag/2.2.0
Reply 15 of 16, by kolderman
Latest release - Version 2.3.0
- Full Glide support for DOSBox-X, Staging and Pure Unleashed.
- Automatic Save State directory for DOSBox-X.
- 7za.exe added as a pre-configured packer.
- Build environment upgraded to RAD 13 (Delphi 13 Florence).
- [Removed] The old 7zip DLL interface and ZipMaster.
https://github.com/cyberfox1/dfendx/releases/tag/2.3.0
Reply 16 of 16, by kolderman
Latest release - Version 2.4.0
- Major overhaul of ScummVM profile support.
- Presentation mode/dos-rate options for Staging.
- Updated help/wiki to cover most DFendX features.
- [Fix] Crash when installing from source media.
https://github.com/cyberfox1/dfendx/releases/tag/2.4.0
