The quest for the perfect retro laptop: a saga
Reply 1140 of 1158, by BitWrangler
megatron-uk wrote on 2026-04-24, 11:54:
Well my Thinkpad T43 failed on me today :( […]
Well my Thinkpad T43 failed on me today 🙁
After reading a couple of the later posts here I though I would pull it off the shelf, charge the battery and see about replacing the soundfont I was using with VSBHDA with something larger (I mean, I've got 1GB of RAM for DOS... let's use it for something!)... sadly, whilst the battery charged (amber -> green indicator after an hour or two) it won't power on. The PSU and battery indicators light up, the cpu fan spins, but the screen is dead and there's no POST/beep messages. Tried on battery, on psu, on both, removed battery, held power button, reseated ram, etc.. all the normal tricks... it just won't POST.
I guess I'm in the market for a replacement:
- Later Pentium-M or Core Solo/Duo
- Minimum 1024x768 screen - absolutely must be 4:3 aspect
- Must have chipset supported by SBEMU/VSBHDA
- Trackpad preferred - nub controllers are a pain for gameplay
- Not too physically big/heavy - I've a lovely Armada 1750, but don't use it because it's so brick-like
Currently thinking: Thinkpad T60, T61, R51, R60, R61 (but most of the these were specced with 16:9 options), Compaq Nx6310, Dell D520
All the Acer note and netbooks I've got have held up very well for their age, so I would suggest looking at Acer Travelmate models with Pentium M or Centrino tech.
Reply 1141 of 1158, by leonk
I'm actually not surprised. This is the era of bumpgate; the issue that plagued the entire industry (2005-2010 ) The most famous victim here is the XBOX 360 with its RROD. But it also effected PS3, GPUs and laptops. I remember that's how my T43p died at work (and I was mostly using a dock at the time to a connected monitor). The T61 replacement I got was more reliable; the thing that killed it which resulted in me being switched to a Macbook Pro was it falling out my hands and cracking the LCD screen.
Reply 1142 of 1158, by 3lectr1c
T43 works fine with a dead CMOS battery. Probably either the GPU or Southbridge failed. T43 is unfortunately not the most reliable laptop 🙁
Owner of https://www.macdat.net, the largest vintage laptop documentation resource on the web!
Reply 1143 of 1158, by megatron-uk
3lectr1c wrote on 2026-04-24, 12:50:
Yeah, I've much older Thinkpads (385ED, 600X, 240) that still work great. The T43 came to me as a bit of a basket case: the backlight had failed (replaced it with new screen and inverter), I also had to replace the heatsink fan (seized up) and thermal paste and interface material. I suspect it had a hard life before then and may have been on its last legs. Shame, as before it went onto the shelf I had gotten it into a nice working state.
https://www.target-earth.net
Reply 1144 of 1158, by dr_st
Have you tried specifically the static discharge voodoo? It never helped me with anything, but there are evidence that sometimes it works on that generation of machines.
Reply 1145 of 1158, by MAZter
Thinkpad T40 works fine with sound in most late DOS games using SBEMU. And even with some early DOS games could work (with NOEMS option).
The attachment 2026-04-24 20.39.25.jpg is no longer available
I really like how Screamer 1/2 game runs on it, smooth and cool.
The attachment 2026-04-24 20.38.05.jpg is no longer available
The attachment 2026-04-24 20.36.46.jpg is no longer available
At the same time, the graphics in Big Red Racing suffer from significant ghosting:
The attachment ghost.jpg is no longer available
In Grand Prix Unlimited, for example, music plays only during the intro sequence and then stops completely.
Reply 1146 of 1158, by megatron-uk
dr_st wrote on 2026-04-24, 20:37:
It was worth doing, so I just tried it this morning - all combinations of hammering the power button as quickly as possible, pressing and holding for 0.5-1.0s... no change in behaviour. It's dead, Jim:
The attachment IMG20260425073310.jpg is no longer available
I've been on the lookout for replacements and have spotted a clean looking Compaq nx6310 (Intel graphics, 14" 1024x768, 2GB, 1.8 C2D) for not much more than postage costs, as well as numerous Dell D610's in a similar config... though with the Dell I'd prefer to find one with the ATI X300 discrete graphics and the 1400x1050 panel as that is the spicy one. Somewhat similar would be the Dell D520, but that's closer to the Compaq as it isn't available with a discrete graphics option.
Reply 1147 of 1158, by megatron-uk
Got three new candidates on the way to replace the dead T43:
HP/Compaq nc6000
- 32MB ATI Mobility Radeon 9600
- 14" 1024x768
- Unknown CPU, RAM, disk
HP/Compaq nx6310
- C2D T2400
- 2GB RAM
- 128GB SSD
- 14" 1024x768
Dell Inspiron 600m
- Pentium-M 1.7
- 2GB RAM
- 40GB
- 14" 1400x1050
- ATI Mobility Radeon 9000
Hopefully since at least the nx6310 and 600m have ICH/AC97 audio, they should work with SBEMU/VSBHDA. Not sure about the nc6000 as it's a little older with the ICH-4 controller... it was cheap enough to give it a try.
Reply 1148 of 1158, by MAZter
https://ebay.io/m/BtORRb
Sager FMA86T, great laptop for Dos gaming, everything works before Windows loading including GAMEPORT!
Reply 1149 of 1158, by Intel486dx33
These old Sony Vaio work great for playing games.
Easy to repair, upgrade and fix.
The only drawback might be the keyboard keys.
And small trackpad.
But with windows xp installed they work great.
Reply 1150 of 1158, by Lorenzo04
Hi, I bought a Fujitsu Siemens Scenic 750AGP and I'm reinstalling Windows 98 SE (because the old hard drive was broken). Does anyone know what kind of sound card it has, because I can't find or install the drivers? Does anyone happen to have the drivers I can install?
Thanks in advance for your reply
Reply 1151 of 1158, by MAZter
Lorenzo04 wrote on 2026-07-17, 20:19:
Hi Lorenzo04, I have this nice notebook in my collection. Here specs:
Fujitsu Siemens Mobile Scenic 750AGP
13.3" TFT (1024x768) detachable! screen
3D Rage LT Pro (4Mb)
Pentium II 366Mhz (180 Mhz using cpuslow button)
2 x 128Mb memory
FDD Citizen W1D/CD-ROM combo, or optional DVD drive exchangeable
Sound card: not sure, ES1938 (Solo 1) / ES1940 / ES1869
1 USB, S-Video, Audio line-in (+1 for microphone)
Here what files I have for it:
Manual:
The attachment mobile_750.pdf is no longer available
Intel chipset driver:
The attachment infinst_enu.exe is no longer available
Video driver: I don't remember exactly, you can try one of this:
https://www.philscomputerlab.com/ati-9x-driver-archive.html
https://dosdays.co.uk/media/ati/3D%20Rage%20II/Vga.zip
https://drive.google.com/file/d/1iCLskUJHu4pT … RJuNMgCjXXneR5s
The attachment FTS_DisplayATITechnologiesRage_535_1002256.ZIP is no longer available
Additionally you can use Riva Tuner 2.24c:
https://www.philscomputerlab.com/riva-tuner.html
Audio driver:
For DOS:
The attachment ES1938.zip is no longer available
For Windows:
https://ps-2.kev009.com/pccbbs/aptiva/an1z00us.exe
or/and
https://ps-2.kev009.com/pccbbs/aptiva/ao1z00us.exe
Reply 1152 of 1158, by Lorenzo04
Thank you!
Reply 1153 of 1158, by Lorenzo04
Hello, I have another question about my Fujitsu Siemens 750agp... I would like to use it to capture old mini dv movies, but when I do the movies lose frames. Do you think if I bring the RAM from 64 to 256mb it should be enough? Because in addition to RAM the rest of the features should be good to run Premiere 6.0. In addition to the RAM I have activated the dma on the hdd. If you have any other tips or mistakes in installing the FireWire card on win98 tell me!
Reply 1154 of 1158, by Thermalwrong
The Compaq Armada 1598DT / 1598DMT is my current pick for the best there is:
- Pentium MMX 266 Tillamook CPU
- Integrated AC PSU, floppy drive and optical drive
- 13.3" 1024x768 TFT screen
- Chips & Technologies graphics chip
- 3:1 integer scaling of 320x240 graphics to 960x720 with black bars surrounding - perfect scaling
- ESS audio, but no wavetable and requires an unknown port replicator for gameport/midi
- best speakers I've seen or heard on a laptop, ever. The Armada 1700 / 1750 speakers are about the same
- physical volume up / down buttons on the side
I think the discovery of 3:1 integer scaling only happened because I started up a game with scaling turned off and usually I'd turn scaling on - you can enable or disable scaling with Fn+T which scales the display up to the full 1024x768 resolution which gives uneven scaling of some pixel columns. I think it was disabled and just by default did the 3:1 scaling of 320x240 which I think makes its pixels bigger than a 10.4" 640x480 TFT?
Reply 1155 of 1158, by keenmaster486
How does it handle 320x200?
World's foremost 486 enjoyer.
Reply 1156 of 1158, by Thermalwrong
keenmaster486 wrote on 2026-08-31, 20:42:
Yeah, misremembered it as 320x240. Here's 320x200, so it's outputting at 960x600 on the 1024x768 panel. I really like integer scaling so black bars without a distorted image are my preference:
Reply 1157 of 1158, by keenmaster486
That looks really nice. Does it do the same thing in EGA modes? I have encountered chips that do that integer scaling in VGA but not EGA. Also does it properly handle pel panning? You can test both of these by checking if Commander Keen 4 has uniform pixel sizes and scrolls smoothly.
Reply 1158 of 1158, by Thermalwrong
keenmaster486 wrote on 2026-08-31, 22:38:
And that's a disaster:
The attachment IMG_0573 (Custom).JPG is no longer available
The attachment IMG_0576 (Custom).JPG is no longer available
Dang, maybe it sees it as 640 pixels instead of 320
Testing the same Commander Keen 4 on the Tecra 8200 equipped with its 1400x1050 LCD panel though, that did pass the test! A little juddery, definitely playable and pixel perfect with its Trident graphics, there was some strangeness with some of the credits text moving while doing the scrolling fullscreen COMMANDER KEEN letters but otherwise pretty good.
