386 SX as Psuedo 286?
First post, by RetroPCCupboard
Is there anyone with a 286 that could compare their speeds to my slowed 386 SX please?
I have a 33Mhz 386 SX that I can run at 8.33Mhz by toggling a register in the chipset (OPTi 82C283). This was done by writing a little utility in ASM that writes to ports 22H and 24H to toggle the speed of the clock divider between 2 (33Mhz) and 8 (8.33mhz).
I am using the DOS Benchmark Pack from Phils Computer Lab.
386 at 8.33Mhz
3DBench 1.0 = 2.6
Chris's 3D Bench = crash - coprocessor not available error
PC Player Bench = 0.4
System Information 8.0 = 24.6 (it seems to reset the CPU to 33.33Mhz)
Landmark = 10Mhz AT
Top Bench = 19
Speedsys 4.78 =stuck on determining memory type
386 at 33.33Mhz
3DBench 1.0 = 10.1
PC Player Bench =1.7
Landmark = 41Mhz AT
Top Bench = 67
Reply 1 of 8, by RetroPCCupboard
I should mention that I did check Phil's thread but it does not seem that anyone submitted any 286 benchmarks to his spreadsheet:
Phil's Ultimate VGA Benchmark Database Project
Also if anyone is interested in the util program then I can tidy it up and post it, or the source.
Reply 2 of 8, by Grzyb
My 286 box is offline now, but you can see its Landmark results here - Re: How many Landmark benchmarks?
Anyway, it's a well-known fact that per megahertz, the 286 is slightly faster than 386SX.
386SX has MMU = extra logic between the CPU core and memory = slowdown
In 2003, I voted in favour of joining the European Union. However, due to later developments - especially the restrictions on cash usage - I have withdrawn my support. DOWN WITH THE EU!
Reply 3 of 8, by Shponglefan
I have a 286 that runs at 12MHz and 8MHz.
12MHz:
3D Bench: 3.9
Sys Info CPU: 6.7
8MHz:
3D Bench: 2.6
Sys Info CPU: 4.4
I also benchmarked Doom using a 386 overdrive chip at 12MHz. From what I remember I got 0.6FPS.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 4 of 8, by Shponglefan
Grzyb wrote on 2026-09-02, 12:26:
Can confirm. Running a 386 overdrive on my 286 system, I recall all benchmarks being slightly slower than using a native 286 processor.
Reply 5 of 8, by RetroPCCupboard
Shponglefan wrote on 2026-09-02, 12:30:
I have a 286 that runs at 12MHz and 8MHz. […]
12MHz:
3D Bench: 3.9
Sys Info CPU: 6.7
8MHz:
3D Bench: 2.6
Sys Info CPU: 4.4
Thanks. So going by the 3D Bench then, it seems marginally faster than your 286 at 8Mhz .
Reply 6 of 8, by RetroPCCupboard
Hmmm. Well that tool varying the result so much between versions is rather concerning.
Yeah, I had read this. It is quite interesting
I am not sure what speed sensitive games to try on it yet. The only one I have tried so far is Police Quest 2 (GOG release). I think the intro was still a little too fast.
Reply 7 of 8, by maxtherabbit
RetroPCCupboard wrote on 2026-09-02, 12:37:
12MHz:
3D Bench: 3.9
Sys Info CPU: 6.7
8MHz:
3D Bench: 2.6
Sys Info CPU: 4.4
It's meaningless to compare 3dbench results across platforms unless the VGA card is identical
Reply 8 of 8, by RetroPCCupboard
maxtherabbit wrote on 2026-09-02, 14:35:
I'd argue that it's not meaningless. Though I agree that video card will have an impact.
In my case I am trying to judge whether my slowed 386 SX is comparable to an average 286 for the purpose of gaming. Mismatched hardware is kind of the point. I don't wish to add a slow video card to it to make it more 286-like as, primarily, I want to use it as a 386 SX 33Mhz.
I am using the onboard graphics. I am not entirely sure what it is, but it is S3 of some sort. It seems to have good compatability with games like Commander Keen.
Basically I want to be able to play any DOS game with 3 PCs. I think the following will cover most things:
- NuXT with 8088 (4.77-9.54Mz)
- 386 SX (8.88-33.33Mhz
- Pentium MMX (200-300Mhz, plus SETMUL for slowing it down)
