First post, by plasticfactory
I'm looking for cardbus adapters (USB, wifi, etc.) that have the additional hardware mounted "backwards". IE, rotated around the device 180*.
For example, my Dell Inspiron 8200 has two cardbus ports, but I can only use one at a time if I want to leave my Audigy card hooked up due to physical interference. If I could install the cards back-to-back it wouldn't matter.
Hopefully this makes sense, and hopefully someone has a suggestion!
