Reply 360 of 362, by zami555
mwdmeyer wrote on 2026-08-15, 03:37:
if you can run the dos exe I can collect info about your card and try and build a supported driver
Nice to see your great work. I'm impressed with what you'd like to achieve and crossing my fingers for success.
I believe so far nobody attached some results from survey tool so please find atached the results from my computer. It's the VLB card with S3 Trio64V+ chip (86C765) designed by Madao.
The mainboard in my computer is a bit uncommon as it uses EDRAM. There could be something suspicious in results as I'm experiencing issues with this card in Windows 3.11. None of the drivers dedicated for this S3 chip works there. Just plain VGA 3.0 driver works. In contrast in DOS everything works without any issue. (some details can be found here: Re: S3 ViRGE VLB project (or " Making a Concurrent for Creative 3D Blaster VLB" ))
Reply 361 of 362, by Oerg866
I do have a VIRGE VLB card (prometheus) but without any hardware changes, running on TRIO64V+ VBIOS, so it's likely useless. But if I get the time I can do some tests for you
