Reply 20 of 24, by Benedikt
After not having touched my clone cards for some time, I recently got my hands on a more fitting CMOS oscillator, namely one with 2.4576 MHz instead of the 2 MHz I initially tried.
Feeding that clock frequency into the PSGs (instead of the approx. 2.3864 MHz of the halved ISA bus clock) yields audio output that is only off by almost exactly half a semitone.
That is less than the traditional “PAL shift” caused by broadcasting 24 FPS movies at 25 FPS and therefore essentially not noticeable, unless you are blessed (or in this case cursed) with perfect pitch hearing.
