First post, by Sly_Botts
- Member
Hi everyone,
So I decided I wanted to retire my Pentium 4 Prescott 3.2Ghz ASUS P4P800X system and try to build a modest 2005 Windows XP system.
CPU: Socket 939 Athlon 64 X2 4200+ Manchester
Motherboard: ASUS A8V-MX
RAM: 1GB DDR1 PC3200 2-3-3-7-10 timings
Sound: Sound Blaster Audigy 2 ZS
Video: ATI Radeon x800 pro 256MB
Storage: WD 250GB SATA III SSD with SATA to IDE Adaptor by StarTech
So I was able to obtain this motherboard from ebay for a fairly expensive price. (65 Euro's plus 35 shipping to Canada). My options were very limited as most Socket 939 Motherboards I could find were PCIe only and those that had an AGP slot were very expensive (Hundreds of Dollars). So i settled for this one despite my fears of it having a VIA chipset.
Let me tell you, this was quite the time.
First I discovered that the Chipset VIA VT8251 doesn't play well with SATA drives that are not SATA I or II (mostly just SATA I) However it could detect the SSD despite it being SATA III and I was able to get windows XP installed and run it in RAID MODE. AHCI was not recommended for this MB as apparently the chipset was designed to run SATA drives in RAID mode to perform the same function as AHCI. Despite this SSD being detected and useable, it would cause issues while running Windows XP. Files would get deleted or drivers deleted, settings changed etc; Very strange behaviour, so I decided to bypass the SATA controller altogether.
The other issue with this motherboard which killed it for me initially was that there are issues with the 8M800 AGP chipset not being able to handle fast ATI cards and many others. There were some Nvidia cards that would work (See 6600 GT) but I bought this to utilize my x800 pro. So I was determined to make it work as it would crash any time I tried to play a game or run any benchmarks. So here is what I did after 3 days of troubleshooting:
1: Update the Bios: I updated the bios to the latest 0503 bios
2: In the bios I had to make sure my AGP settings were specific:
3: I wiped my drives and did a fresh install of XP 32-bit SP3
4: Once XP was installed I installed the VIA 4in1 chipset ver.456, followed by ver.524a. Right after this I went into device manager, found the VIA CPU-AGP controller and made sure the driver was updated to VIA CPU to AGP2.0/AGP3.0 Controller
5: Installed AMD Dual-Core Optimizer patch for XP and the AMD K8 processor drivers for the X2
6: Installed .Net frameworks and drivers for Sound Blaster AUdigy.
7: Finally installed Catalyst 5.13 for the x800pro.
8: System reboots, it automatically turns off AGP Read, AGP Write, PCI Read and PCI write because of SmartGart.
9: Turn on AGP Read, AGP Write, reboot.
10: Turn on PCI Read, PCI write, reboot.
Enjoy Games.
On a side note: After all this, I am noticing some chirping on the sound card when I'm playing games or music. I'm going to look into this.
*UPDATE*
I was unable to fix the "chirping" issue using the George Breese VIA PCI Latency Patch, so I opted to use a non Creative card in Windows XP
However I was able to get this system to also run windows 98se without issues, using the Audigy 2 sz. I guess there must be something with the way XP handles PCI buses, I don't know but the Audigy runs great in win98 and will even emulate an SB16 so a good number of DOS games will work. Unfortunately my motherboard doesn't work with SB16 emulation in DOS with the Audigy2 even with the patch.
AMD Athlon 64 X2 4200+ 2.2Ghz (AGP ASUS A8VMX WINXP)
3dMark 2000: 19433
3dMark 2001: 27092
3dMark 2003: 14532
3dMark 2005: 6569
3dMark 2006: 2615
AMD Athlon 64 X2 4200+ 2.2Ghz (AGP ASUS A8VMX WIN98 SE)
3dMark 1999: 24829
3dMark 2000: 20520
3dMark 2001: 18128
3dMark 2003: 12079
It is possible to commit no errors and still lose. That is not a weakness, that is life.
